gaskets/bolts needed for heads
I'm putting a new LS1 in my TA... the heads are off the new engine. What gaskets/bolts will I need to get this thing running, keeping in mind it still isn't in the car. Will I only need 2 head gaskets and a new set of head bolts?
Originally Posted by bigdsz
At SDPC LS1 head bolt kit[ one head] part number 12498545 $16.95/set. 1997-2001 LS1/LS6 head gasket kit[both heads] part number 12498543 $34.95. Hope this helps.
I'm putting a new LS1 in (complete engine). The heads are off of the new motor, so I need to put them back on. Is this all that I'll need to do it?
By the way, thank you very much for the part numbers!
