Change Valve Springs
Originally Posted by Locke434
Is upgrading to Comp 918 Valve springs better then stock?
Are you swapping your stock cam for an aftermarket cam? If not then don't do it as it's not necessary and you might end up losing power as the 918s are stiffer than the stock springs. The stock valvesprings can easily handle the measely lift of the stock cam.
