Do 6.0 truck heads flow better than 5.7 LS1 heads?
Old 07-22-2004, 12:47 PM
STF Veteran
99-LS1-SS's Avatar
Default Do 6.0 truck heads flow better than 5.7 LS1 heads?
I was wondering if the 6.0 truck heads flow better than the 5.7 heads right from the factory.
The reason I as is would it be any improvement in power to switch to a set of stock 6.0 liter heads from my stock 5.7 liter heads.
Old 07-22-2004, 01:10 PM
Boostaholic's Avatar
I'm also intrested in this
Old 07-22-2004, 01:12 PM
kickassT/A's Avatar
the LQ9 heads flow better, as they are a big chamber ls6 head. i dunno if it would be worth the swap though, seeing as you would loose compression. they work well in forced induction apps though.
Old 07-22-2004, 01:14 PM
Moderator
xp3nd4bl3's Avatar
Yeah, you'd at least want to get them milled. Or perhaps you could use a really thin head gasket. The LQ9 heads port really well too.
Old 07-22-2004, 01:39 PM
Ravenous T\A's Avatar
Thats what Patriot uses for there LS6 heads special, LQ9 is same design as the LS6 but with lower compression ( I think thats it, might of left something out)
Old 07-22-2004, 04:03 PM
Another_User's Avatar
my understanding is that they are the exact same design as the LS6 head with a larger CC chamber to lower the compression ratio (agreement). Unless you are doing something to maintain your current compression ratio, or increase it I would not do it. Lower compression ratios have a lower volumetric efficiency at all RPMs and you will lose horsepower and torque across the band, and maybe gain a little way way up in the RPM band due to better flow...maybe. I would love to see a dyno chart, but I doubt you would like to see it. It would suck. I think the amount you would have to shave would be too much, which is why the head companied that use them fill up the extra space with some filler or weld or something. You could switch pistons though. Now if you are going for a blown application, yes they would work out awesome. But...you would probably still want to replace your pistons so you don't blow a hole in one (or more).
Old 07-22-2004, 04:30 PM
jrp
SN95 Director
jrp's Avatar
and check my cam guide for the stock flow numbers.
Old 07-22-2004, 04:34 PM
ls6jimmy's Avatar
0.30 will give you 10:1 compression and you wouldn't have to modify your intake. And you could take as much as 0.70 but your intake would need modification's
Old 07-22-2004, 04:59 PM
LS1derfull's Avatar
Question
So would your pistons, extra valve reliefs. .070"off heads with any cam would come up shy. Do a search about 6.0 vs. ls6 heads because there is a intake port design difference. Someone has chimed in about this in the past, maybe Brian Tooley from TEA.
Old 07-22-2004, 05:02 PM
JZ'sTA's Avatar
Yo jrp I read the whole thing, no where did it show stock head flow numbers.
Old 07-22-2004, 05:03 PM
toxic99's Avatar
I looked at your "cam guide" and I don't see any flow numbers, as in, head flow #s. If that is what you were refering to? I am trying to find stock head flow #s for 241s.
Old 07-22-2004, 05:06 PM
jrp
SN95 Director
jrp's Avatar
lol, im a dumbass, your right. i though i put that **** in there but i didnt. was gonna make a head guide as well but never got around to it. anyway here it is:
http://ourworld.cs.com/jrpws6/heads+...ckheadflow.jpg
Old 07-22-2004, 05:58 PM
STF Veteran
99-LS1-SS's Avatar
Can you translate the columns for me?
L/D
Full CFM
Test Pres
Flow Pres
Corr CFM
Old 07-22-2004, 06:09 PM
jrp
SN95 Director
jrp's Avatar
L/D
Full CFM
Test Pres
Flow Pres
Corr CFM
what the heads flow are the Corr CFM.
Old 07-22-2004, 07:57 PM
toxic99's Avatar
Thanks for link JRP.
Old 07-22-2004, 09:01 PM
fast98's Avatar
whats the bore on a 6.0 stock?
Old 07-22-2004, 10:47 PM
jrp
SN95 Director
jrp's Avatar
4" bore
Old 07-23-2004, 08:50 AM
marc_w's Avatar
I could have SWORE that LQ4's (9.4:1, "regular" truck motor), and the LQ9 (10:1 Silverado SS, Caddy SUV motors) all use the same heads?
The compression from my LQ9 comes from flat-top pistons.
Old 07-23-2004, 06:21 PM
toxic99's Avatar
LQ4s came with cast iron heads and aluminum. LQ9s came with aluminum.
Old 07-23-2004, 10:39 PM
jrp
SN95 Director
jrp's Avatar
only the 99-00 LQ4's got the iron heads, all 01+ got the same 317 or 052 (i think) aluminum heads.
Quick Reply: Do 6.0 truck heads flow better than 5.7 LS1 heads?
