guys with heads and big cams,what lifters are you using?
Old 07-23-2004, 09:39 PM
mike c.'s Avatar
Default guys with heads and big cams,what lifters are you using?
i have all boltons heads and the g5x2 cam. i was thinking of loosing my comp r lifters,all the preload problem stories make me wonder if i should keep them. is there any other lifters that work as good with less problems. i have stock rockers and would like to keep them(if i can). what are you guys using?thanks, mike c.
Old 07-23-2004, 09:47 PM
gomer's Avatar
IMHO the only lifters I'd install are the GM stock lifters are the Comp 850 stock replacement lifters.. I've heard too many horror stories of people using the Comp "R" lifters and trying to achieve the correct preload. Btw.. I'm still running stock GM lifters after 20k of aftermarket cams without a single problem.
Old 07-23-2004, 09:56 PM
destroyerSS's Avatar
It depends on what springs you use. With my stiff 977's i went with comp r's because i think the springs would have collapsed my stock lifters.
Old 07-23-2004, 10:01 PM
offaxis's Avatar
Stock Is the way to go especially if you are doing the work yourself. If you had a top shop doing it they should be able to shim correctly for the comp r`s . I just wouldnt mess with them unless i had adjustable rocker arms.
Old 07-23-2004, 10:03 PM
theblur98ss's Avatar
I'm using comp r's with no trouble.
Old 07-23-2004, 10:05 PM
offaxis's Avatar
I got a few friends running them no problems and I have a few friends with lots of problems. Im just not a fan
Old 07-24-2004, 03:01 AM
PREDATOR-Z's Avatar
Comp 850-16 is what I would go with (actually what I will go with)
Old 07-24-2004, 01:13 PM
DaleMX's Avatar
It's just a TR230, but I'm using Comp 850-16 also. Jay at Absolute Speed told me that the Comp R's were not necessary and that alot of folks have issues with setting them up.
Dale
Old 07-24-2004, 04:22 PM
mike c.'s Avatar
i have stock rockers w/comp 921 springs could i use the 850 lifters? are they just as strong as the comp r's?
Old 07-24-2004, 06:35 PM
Suspended Sponsor Account
ForceFed HP's Avatar
we are probably going to use schubeck lifters in our 408 ironblock. the cam has some pretty aggressive specs for a hyd. roller. the schubecks' are a bit pricey though.
Old 07-24-2004, 06:42 PM
98_1LE's Avatar
I have PP LS6 "style" heads and 231/237 cam, and run the OEM lifters. No problems so far.
Old 07-24-2004, 07:17 PM
LS1Tech Sponsor
Slowhawk's Avatar
I've run cams as big as 242/250 with .630 lift and Crane dual springs with stock lifters.No problems here.Not a fan of the Comp R's.
Old 07-24-2004, 08:01 PM
Bink's Avatar
Stock here. 239/251, .570". 918s. No problems.
