New Dyno numbers
New Dyno numbers
I just got back from RPM. It was 97 out side and there dyno is know for low numbers. I had a blast but did not get the numbers i wanted but almost. Check sig for mods. Tell me what u think.
This is my old set up vs my new set up. New put down the bigger numbers
I was not reving to 7000+ that is how the dyno was reading. Something to do with the stall. If i was spining that high i would have go boom with 70k on the stock short block.
Ah so..
The bottom graph looked a little fat on the AF as rpm increased (Dificult to judge). What i don't like is the innability to see any under the curve trq #'s down low.
Should have started the runs at 3K to get a better pic.
We did start at 3k but sence i have a pt4000 it is at 4500-5000 on the dyno no mater what. If you can imagen the TQ spike is at 3k and if u scale it right i stop pulling at 6700 (red line)
