Help with comp R's!
Old 07-24-2004, 11:34 PM
6 Second Club Moderator
LASTLS1's Avatar
Default Help with comp R's!
Someone has to know of a cold setting on the comp R's. It says pre load of 2-4 thou. Hot. But setting them up cold, whats the magic number? The grow rate on the block can't be that different from engine to engine. I have adj. shaft mounts so I want to get them right. Someone has to have done enough of them to know what to set them up cold. Thanks Andy.
Old 07-25-2004, 02:55 AM
PREDATOR-Z's Avatar
Go to advanced search "Comp R" in the internal section. There is quite a few threads on this.
Old 07-25-2004, 09:58 AM
LASTLS1's Avatar
I was looking in there. Too much to read. I need to get this motor in today.
Old 07-25-2004, 08:48 PM
SAM98WS6's Avatar
.008-.010"...about 1/5th of a turn
Old 07-25-2004, 08:50 PM
Senior Member
Country Boy's Avatar
I set mine to ~.010 cold and has worked fine spinning to 6900
Old 07-25-2004, 09:19 PM
Squintz Palladoris's Avatar
1/4 to 1/2 a turn is what I turned up when I searched for this info. I have done two motors this way and it was succesfull. The only way to tell how much preload you have is to put a dial indicator on the rocker just over the pushrod and measure when you tighten it past 0 lash.
Brad
Old 07-26-2004, 04:46 PM
LASTLS1's Avatar
Thanks guys. I set them at .015. 1/4 turn past 0 lash with the jessel shaft mounts. Thanks again. I 'll let you know how it works out.
Old 07-26-2004, 05:30 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
.010 cold works fine. Have spun my car to 7000 on the dyno with them a number of times.
