eagle I beam rods
Old 07-28-2004, 06:17 AM
30th t/a's Avatar
Default eagle I beam rods
will the eagle I beam rods last in a supercharged engine or should i go with something better? what would be the max boost & rwhp you would run with thtese rods?
Old 07-28-2004, 11:05 AM
TT-TECH Veteran
Inspector12's Avatar
I was looking at these also they are advertised to handle 700 hp But I have been making that at the flywheel with the stockers so I am not sure weather I should change them or not. I can not afford the others on the market right now $1000+. I found them new for $369.99 + shipping I thought it was a good deal if I did decide to go with them though.
Old 07-28-2004, 11:15 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
I am using Eagle 6.125 rods and my motor is set up to spin to 7200.
Old 07-28-2004, 11:56 AM
8 second mod
Noyzee's Avatar
Im using Lunati, they are rated a little better, but still afordable. i got mine from speed inc for around 650 i think. thats with arp bolts. Mine are also 6.125
Old 07-28-2004, 02:14 PM
Brains's Avatar
The Eagle SIR I-beams are rated that high?? I know the H-beams are, but wasn't sure about the I-beams..
Old 07-31-2004, 11:48 PM
Redline-Motorsports's Avatar
What are the H-beams rated for? How much are then generally?
Old 08-02-2004, 08:01 AM
BRIAN98Z28's Avatar
I saw an advertisement for the I beams and it said they were rated to 500hp max applications.
Old 08-02-2004, 09:54 AM
8 second mod
Noyzee's Avatar
i dont believe they are much better then stock rods, but run around 500 bucks
Old 08-02-2004, 10:01 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We have both the I beam rods & the H beam rods in stock. I would definately lean towards the H beam rods, the I beams look really cheap & probably can't take alot of hp
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
