help - locking flywheel for cam swap...
I'm tearing stuff down on my truck for my cam swap, and I am having trouble locking my flywheel. LS1howto says that I can wedge a screwdriver in the flywheel, but I'm not quite sure how. Do I just stick in vertically up in there, or do I slide a slim screwdriver in between two teeth and have some1 rotate the crank? I'ld like to just wedge it in there vertically and get up and rotate the crank to wedge it (b/c I am alone and that's the only way to do it alone IMO).
I have to use a lot of torque to break this balancer bolt loose, so.....it would seem like it would just shear off the screwdriver no mater how I put it in.
Thanks,
Derek
Thanks,
Derek
hey. there is a tool called a flywheel/flexplate turning tool you can get that latches down on the teeth of the flywhee. i have used one and they work great. you can get it from Jegs. part #555-80530 $24.99
If you dont have the time. Take the starter off. Spin the motor you will see holes in the fly wheel. Get a chizel (sp) high grade steal. Now put it in the hole. This will do the trick.
I just so happen to have some high grade steel chisels laying around.
These holes will be further up towards the center of the flywheel, correct? How far is the torque converter back from that, and do I risk damaging it using this method?
How did you end up getting the bolt off? I've got a tentative cam swap planned this weekend.
I'm thinking about heading down to the local dealer for the Kent-Moore tool. I don't think I'm comfortable with jamming stuff in the flywheel - but I haven't taken a look at anything yet to say for sure.
I had my lil sister rotate the crank, lol. I found some holes that where just barely accesable from the opening that taking off the bellhousing cover created. I then put a really strong chisel in there and told her to rotate. She yanked on it and it locked the flywheel. I then took a breaker bar, and slid it over the ratchet, then slide a jack handle in the breaker bar. I gave it some tugging and it loosened.
Thanks.
So the chisel get kind of cocked in the flywheel hole, and jams up agains the bellhousing hole?
I wonder if I could use my compressor to air up a cylinder, and use that cylinder to 'lock' the motor. Would the air in the cylinder compress too easily to get a good sharp tug on the bolt? Maybe the compressor would be better put to use with my 250ft/lb impact gun?
A trick that I use on my two stroke motors will probably make some people cringe. I remove the spark plug, move the piston down to BDC. I bring it up about halfway to cover most of the intake/exhaust ports. I snick the tranny in gear, and hold the piston in that general area via the countershaft sprocket. I then stuff a standard fabric ROPE into the plug hole. I stuff in as much as I can, while holding the piston around mid-bore. (of course I need to leave some hanging out for removal). When I go to remove the countershaft nut (crank pulley bolt in the ls1's case), I crank on the nut, the piston moves up, and compresses the rope. The rope doesn't allow the piston to pass TDC, so the motor is effectively locked.
David
Originally Posted by marc_w
I just went to the dealer looking for the Kent Moore tool. They told me they don't sell tools, and they're not sure if KM deals with "private" sales.
TT-TECH Veteran
Well if all that doesn't work nothing will LOL! Another option is to use an impact before you take the belt or the sparkplugs out it has worked every time except once and I just had some one hold a screwdriver in the flywheel through the little opening on the bellhousing etc... Also note that I have a good snapon impact I don't think the little cheapies will do it, but who knows they might? Good luck!
Found this damper holding tool through SN. $88!
REmove the small 2 in round plug on bottom of bellhouseing insert a BIg screw driver or pry bar into the teeth of fly wheel ( you will need a freind to help) may need to insert one behind the flap behind the starter also >>>( NO need to remove the starter) OR you may order the special tool from GM which will bolt to block which will hold the fly wheel
get a big peice of pipe to use as cheater on on ratchet or breaker bar ( some say bind bar and bump starter to loose crank bolt ( I WOULD NEVER DO THIS )
Will need a 3 leg puller that will pull from the inside ( never from outside ) of stock pulley (may rent from local past supplier )
when ready to re install I get two new crank bolts from dealer and weld a 5/8 x 4 in bolt to head of one ,
( will need to grind down the washer on stock bolt so that it will fit threw the pulley) screw the welded crank bolt in to crank slide a socket( one that will just fit inside the pulley- to use as a guide to start pulley stright ) over the welded 5/8 bolt ,use this to pull the puller back on this way you are not puting much strain on the threads inside the crank Lubricate and mount the ASP pulley onto the snout. Once it is pressed close to flush ( about 1/8 being flush) then install old bolt and tighten it to 240 ft. lbs. or until it is completely seated on the crank snout. Afterwards, REMOVE THE STOCK BOLT and replace it with the NEW CRANK BOLT. You will tighten the NEW bolt to 37 ft. lbs. and then turn it an >>additonal 120 degrees.<<<
hope this helps Johnny
ps:: I install a new seal any time I remove a pulley($10.00 and 10 minutes now is better than haveing a leak and haveing to remve pulley again
may make a tool to hold flywheel
hope the drawing of tool is understandable
use a 1/8 x 2 flat bar about 12 in long insert into flywheel threw the round hole in botton of bellhouseing ,the notch in side will hold tool in place
PS: THE DRAWING DOES NOT SHOW UP CORRECT ,it should be about 2 in wide all the way down
You can do it like baskett does. Put the braker bar on the bolt and the in on the ground. Now start the motor. Dont forget to unplug the coil packs.
