Who has an Iron Block in their Daily Driver?
Old 08-03-2004, 03:57 PM
Ragtop 99's Avatar
Default Who has an Iron Block in their Daily Driver?
For those of you with an iron block in your daily driver:
1) How has it affected the car's handling on the street (e.g. taking corners or coming off on the highway onto a cloverleaf and taking it faster than posted speeds)?
2) Any cooling issues?
Let me know if you have A/C installed and regular tires (or skinnies).
Old 08-03-2004, 05:54 PM
770Guy's Avatar
VINCE , from florida has an iron block. Try sending him a PM he can probably tell ya what you wanna know.
Old 08-03-2004, 06:07 PM
Boostaholic's Avatar
I have a iron block on the way, and the front of my car will weigh less than it did with the stock block when I'm done.
Overall, -AC, -AIR, -EGR, -Stock Kmember, -Battery, +Iron block difference
Old 08-03-2004, 09:41 PM
Gold Z's Avatar
I've been running an iron block for over a year now and have put over 10,000 miles on it. I really can't tell any difference in handling but I drive it sanely and don't throw it around corners at high speeds. Overheating has never been a problem even with the air conditioner going in heavy traffic. I drive on factory size tires up front except on the strip I use a set of skinnies.
Old 08-04-2004, 12:00 PM
un4giv3n's Avatar
is the iron block worth the extra weight? Chevy Ls1/Ls6 Performance says no. And does it need to be resleeved just like an aluminum block to get 427 cubes?
Old 08-04-2004, 12:06 PM
Gold Z's Avatar
NA I'd say no, but with a heavy shot of nitrous or other power adders I'd say yes. Mine was built for a lot of nitrous using forged internals and a stock crank. With a .030 overbore I've got 370 cubic inches fairly cheaply.The extra strength and 24 additional cubic inches made it worthwhile for me.
Old 08-04-2004, 12:25 PM
Vents's Avatar
well, jimmy dean, i'd say she's not all that bad..
go with a lower temp thermostat, and you'll be dandy ;D
Old 08-04-2004, 12:31 PM
BLK02WS6's Avatar
I have an iron block and didn't see any difference in handling with 17's - now I drive it all the time on skinnies (not daily though) - no problems that way either.
I think it is a good way to go for some extra cubes on a budget. You can get a brand new 6.0L block much cheaper than an aluminum block. Plus there is the advantage of being able to bore it and rebuild it a couple of times.
I think the extra cubes do help, with the right combination - I am making around 415 at the wheels now and I have unported LS6 heads and a reasonable sized cam (small by some standards). I couldn't afford a stroker crank, so I have a forged 364.
Old 08-04-2004, 12:33 PM
Shorty Director
VINCE's Avatar
I did not notice any difference in handling. Of course I have revalved bilsteins which are designed for 93-97 iron block F-bodies. My car ran cool all the time. Even Allan Futral said he was surprised the car ran so cool. I have AC as well.
