Changing O ring on the oil pump
Old 08-03-2004, 07:22 PM
INMY01TA's Avatar
Default Changing O ring on the oil pump
I've read you have to drop the oil pan to get at the pick up tube to do this. Seems like the K member is in the way but none of the threads I read (did a search) say anything about dropping the K member to do this. Do I have to drop the K member to do this or can I fit the tools between the k/pan and drop it just enough to get at the pick up tube? Thanx in advance.
Old 08-03-2004, 07:50 PM
TT-TECH Veteran
Inspector12's Avatar
Yeah you can change it out with out dropping the K-member. You still will need to losen all the oil pan bolts to get enough clearance to get a 10mm wrench in there. not to bad just take all the bolts out it make it easy on yourself.
Old 08-03-2004, 09:09 PM
Ferocity02's Avatar
Yep, undo all the oil pan bolts and you can drop the pan a little bit to get access to the bolt. It's not easy by any means. Took me a couple hours just to get the bolt started again in the hole without dropping it into the oil pan. Good luck!
Old 08-03-2004, 09:21 PM
TT-TECH Veteran
Yes it can be difficult just becareful and take your time don't get in a rush at that point. A long flexible mangnet will be very helpful got mine from Home Depot. I use one finger to hold it in place and use the open end of the wrench to turn it until it gets started etc...
Old 08-03-2004, 09:22 PM
Krab's Avatar
Like these guys already said, just unbolt all the 10mm bolts holding the pan to the block and the two 15mm bolts that hold it to the bellhousing towards the back and it should drop down about 1.5". Be sure to put something in the oil pan, like a clean rag just incase you accidentally drop the bolt. Because if it drops all the way to the back, well good luck getting it out of there.
Old 08-03-2004, 10:04 PM
WILWAXU's Avatar
If your going in there.. might as well put a new pump.. and cam in
Old 08-03-2004, 10:11 PM
Quick 99's Avatar
i got it, it was only a few bucks for the o ring at the dealer, never can be to safe
Old 08-03-2004, 10:28 PM
TT-TECH Veteran
If you drop it no big deal just pull the low level detector on the side of the oil pan and with a magnet it will fit right out the opening etc...
Old 08-03-2004, 10:36 PM
P Mack's Avatar
If you don't already have the radiator/water pump/pulley/timing cover off, it would probably be easier to just drop the pan completely if all you're doing is changing the o-ring. With the pan off putting the ring in will be a peice of cake, as will bolting up the pick up tube. If you already have the timing cover off, ignore what i just said.
Old 08-03-2004, 10:44 PM
TT-TECH Veteran
I think that taking off the oil pan with out removint the timming chain cover would be harder and I don't think you can get the oil pan out with out dropping the K- member a little. Good luck.
Old 08-04-2004, 05:56 AM
INMY01TA's Avatar
Thanks, sounds like it'll be fun.
Old 08-04-2004, 06:22 AM
mitchntx's Avatar
Why do you think you need to change the O-ring?
Old 08-04-2004, 04:16 PM
INMY01TA's Avatar
Well my timing cover is leaking so I'm gonna swap the gasket and use some RTV around it. My motor's been ticking for a while and while most say its normal for cammed LS1's to tick I figured I'd give this O Ring thing a shot while I'm in there. There's a tsb somewhere that says the ticking can be caused by a torn O ring. What the hell. I'll be in there anyway and the part is cheap enough.
Old 08-04-2004, 05:40 PM
TT-TECH Veteran
Well I think that would show up more in your oil presure rather than a noise? Not saying for fact but if you have good oil presure I would just think that your car has a little noise and that is really comon! But hey if your there I guess you could try it?
Old 08-04-2004, 10:22 PM
glennhl's Avatar
I loosened the pan bolts and dropped the pan down. Still not a lot of room to get to the bolt. I learned a trick from searching on this forum. I used lockwire pliers and put lockwire under the head of the oil tube bolt after I loosened it some. Held it with the lockwire/pliers and kept me from losing it. Left the bolt on the pliers and used that to hold it in place to put it back in. Worked great. Also helps a lot to have a 10mm gearwrench.
Thanks,
Glenn
Old 08-05-2004, 02:30 AM
TT-TECH Veteran
Might work too. I would just becarful and make sure that it seats nice and even. My gear wrenches never work once you even start to get close to the flange. I always just use a boxend wrench with my finger to hold the bolt etc... It is worth at try though.
Old 08-05-2004, 03:04 AM
derek_silvy's Avatar
I am in the middle of my cam swap and I'm having trouble getting my oil pan to drop. I loosened all the oil pan to block bolts, but it still is sealed to the block. I've gently slide a flathead screwdriver in there and pried, and even hit the part left exposed by the timing chain cover being removed with a rubber mallet, but it will not break loose. I didn't unbolt any 15mm bolts. I'm SOOO scared of warping the mating surfaces, so I don't wanna proceed until I get some advice.
Thanks,
Derek
Old 08-05-2004, 11:08 AM
glennhl's Avatar
I had the same problem dropping the pan. If it doesn't want to come down then you didn't get all the bolts loose, trust me on this one. There are two large bolts in the very back that are horizontal, those were the ones that I missed. Take these completely out. If it's not that, then you missed the small bolts that are hidden by the K member.
Once you get all the bolts loose, my pan dropped by itself, took no effort at all. So don't force it, you'll break something.
Thanks,
Glenn
Old 08-05-2004, 11:28 AM
kenkaru's Avatar
derek, you missed some bolts
a bad o-ring can cause ticking because some of the lifters may not get sufficient oil pressure. I'm going in after mine tomorrow.
