Heard some horror stories...
Old 08-05-2004, 10:09 AM
MurrayFormula's Avatar
Default Heard some horror stories...
Switching from conventional oil to synthetic oil. Car has 54000 on it. Just installed a cam and wondering if it will be a problem. I have heard some horror stories from some older race heads and wondering if someone has made the switch. Also, Mobil 1 is it the best to switch to?
Old 08-05-2004, 10:10 AM
marc_w's Avatar
I've never heard of anything going wrong... I've even switched back to conventional oil after running synthetic, with no issues at all.
Old 08-05-2004, 10:22 AM
crainholio's Avatar
A marginal engine with seals worn past their limits will likely leak if switched to synth oil. LS1 and and it's new technology seals is a low-risk candidate even at your 54K miles.
Synth oil will not create leaks by itself. The benefits it brings are worth the risk of finding a marginal seal, in my opinion.
Old 08-05-2004, 10:24 AM
LS1TECH Sponsor
badpewter-z's Avatar
i switched after i put my cam in to synthetic and no issuses 0w40 mobil one and doesnt burn off either ran regular before but i changed it every 2000 too
Old 08-05-2004, 10:28 AM
Humanitarian
Joe "Preachers Sheets" DIESO's Avatar
When I changed my cam I went from Mobil 1 5w-30 regular oil to Mobil 1 Super Syn 0w-40. I change my oil every 6,000 miles instead of 2,500 and I would say I will burn half a quart in those 6,000 miles at most, maybe even 25% of a quart. That's compared to almost a full quart in 2,500 miles of the regular 5w-30 stuff. Made a world of difference.
Switching from regular oil to super syn shouldnt be an issue at all.
Old 08-05-2004, 10:29 AM
frey51's Avatar
Here is what happens. Obviously my details arnt 100% correct, but I know what happens is right.
Synethetic oil essentially has smaller oil particles, which gives it better lubing qualities. If your car has had regular oil in it, the gaskets are used to the thicker oil. They synthetic oil will slowly seap through the gaskets eventually causing them to wear out and leak.
I am not too sure about how well the oem gaskets will handle this, but I have had expeirance with this in my old car. I tried it and it leaked everywhere and I had to replace all the gaskets. BUT it was honda, and I am not sure how an ls1 will react with 54,000 on it. I assume with the technology that our engines have they, it wont be much of a problem. I say try it, and mobil 1 is what I use and recomend.
Old 08-05-2004, 10:31 AM
Humanitarian
I changed my oil @ 56,000 miles and I race the car. Never had an issue. Super Syn oil can handle heat better, it's not thinner. The weight ratings are the same if it's regular oil or super syn.
Old 08-05-2004, 10:38 AM
Zach@Texas-Speed's Avatar
what if my car has 95k on the clock, but doesnt burn a whole lotta oil, i think i should be aight right
Old 08-05-2004, 10:41 AM
Thanks for the help. I will be changing Sat. to Mobil 1 and will post the results later.
LS1TECH Sponsor
mines not leaking either, i will say if you had previous leaks the will be worse with synthetic though but shouldnt create any
Old 08-05-2004, 08:01 PM
hondakiller's Avatar
i changed from dino oil to synthetic at like 65k miles and havent had any issues. from what ive heard, on modern engines swapping between oils isnt a problem as long as you dont mix them together when doing an oil change.
Old 08-05-2004, 08:07 PM
MeanWS6's Avatar
i switched also from dyno to syn mobile 1 after my h/c swap - no issues after two years and about 5K miles
