MTI cam swap-G1 or R1"??
Old 08-08-2004, 02:16 AM
LittleBoyBlu99's Avatar
Default MTI cam swap-G1 or R1"??
I am on a quest to run 10.90's this winter and I am looking at these cams to help me reach this goal.The G1's spec is= 228/232-.588/.575:114 and the R1 is= 232/236-.575/.578:113 which one to choose?
I swapped rear end's from 3.42's to 3.90's and my B1 cam seem to fall flat now above 6400 rpm. Thanks for any help you can give.
Old 08-08-2004, 02:56 AM
Jimmy98Z's Avatar
I would go with the R1 it's a bad *** cam and it's even better with nitrous.
Jimmy
Old 08-08-2004, 03:05 AM
offaxis's Avatar
Go R1
I have it and it makes great power
Old 08-09-2004, 02:49 AM
Thanks guy's " the R1 is my choice also unless someone change's my mind.
Old 08-09-2004, 05:59 AM
00T\A's Avatar
I would say R-1 For N\A applications.
The G-1 sounds like a sweet blower grind.
Old 08-09-2004, 09:45 AM
Colonel's Avatar
Lightbulb
This is for a 346ci NA engine? I don't think I'd go with so much exhaust duration.
Why not the X1? I think it would make pretty much the same HP as the R1 with better drivability.
(The LSA is 113 on the G1 and 114 on the S1, fwiw.)
Old 08-09-2004, 01:01 PM
MTI was not wanting to fly cut my pistons and they felt one of these cams would give me the power and torque I need to run 10's. I have MTI's old Stage II R heads w/2.055 valves. What is the down side to running with exhaust duration this high?
Old 08-09-2004, 01:14 PM
Colonel's Avatar
The only downside to the extra exhaust duration is increased overlap which effects your idle and drivability somewhat. It'll still make just as much power as if it were a single pattern or reverse split cam, all else being equal (it might even make a little more power up top due to the increased scavenging effect of the extra overlap.)
Old 08-10-2004, 12:50 AM
Thanks (Colonel) for the help and I will talk this over withthe guy's at MTI and then decide!
Old 08-10-2004, 06:59 PM
Guys" what kind of hp gain did you get with the R1".
Originally Posted by offaxis
Go R1
Old 08-11-2004, 10:19 AM
Colonel's Avatar
BTW, the R1 is an ancient design that was originally intended for 422ci engines. I used to run it in my 422. I later upgraded to the first S1 cam ever ground. That cam went 9s on motor.
Old 08-11-2004, 11:20 AM
offaxis's Avatar
I really like the r1 . It might be an old design but it works great. I gained a good amount of hp over my tr230 cam. At some points as much as 26 hp and averaged about 15hp gain from 4500 - 6500. Plus I have mine on a 112+4 and I make peak power at 6100 rpms and it pulls through 6800. I also like the fact that its not as hard on the valve springs as some of these larger lift cams and cams with more agressive ramps.
Old 08-11-2004, 02:47 PM
WILWAXU's Avatar
X1 got me into the 10's. Hoping for some low 10.8's this fall.
Talk with the gang at MTI, they'll do you right.
Old 08-11-2004, 07:19 PM
Nice times" MTI talked to me about these two cams" G1 & R1 . The G1 is a new grind that they said makes good power over my B1 and they said the R1 would give me the power I was needing for 10's also. The X1 would require fly cutting because I have the stageII R heads with the larger valves.
Old 08-11-2004, 07:44 PM
What gear & converter size do you guys use"? I have the Yank SY4000 & 3.90 gears. I may upgrade to the harder hitting ST4000 .
Old 08-11-2004, 08:25 PM
scalemaster's Avatar
Are ur head's mill
Old 08-12-2004, 05:17 PM
They are MTI's older stageII R heads w/2.055 valves
Originally Posted by scalemaster
Are ur head's mill
Old 08-12-2004, 05:59 PM
well I got the same heads and was looking in to get a cam for the heads
Old 08-12-2004, 06:07 PM
WILWAXU's Avatar
I run a Yank TP-4200 w/3.73's. I'd recommended a SS-4200. It will feel tigher than your SY do to the difference in STR.
Old 08-12-2004, 08:49 PM
That could be a later mod for Blu"
Quick Reply: MTI cam swap-G1 or R1"??
