Factory Ls1 valve vs spring pressure??
Old 08-17-2004, 12:38 AM
fastsspr's Avatar
Default Factory Ls1 valve vs spring pressure??
The factory valves of the ls1 heads can tolerate valve springs set ups for .625 lift?
Any of you with big cams and factory valves ever broke a valve because the valve sring pressure?
Old 08-17-2004, 12:42 AM
jrp
SN95 Director
jrp's Avatar
if your running the proper spring pressure with your big cam why would you break a valve . if your running inadequate spring pressure you can have valve float and the pistons can touch the valves or the springs can break all together and pistons will smack the valves.
Old 08-17-2004, 01:04 AM
FASTONE's Avatar
Never heard of ls1 valve breaking,have heard of ls6 sodium valves breaking in two!!!!
