What a good lightweight valve?
Old 08-17-2004, 11:17 PM
GrannySShifting's Avatar
Default What a good lightweight valve?
Whats some of the light stuff in steel/titanium and are there any decent flowing valves out there that flow well too? I beleive the LS6 valves are roughly 20-30 grams lighter then stock LS1 valves, and they are roughly 100-110 i think?
Any good stuff thats reasonably priced, or no chance?
Old 08-17-2004, 11:29 PM
FASTONE's Avatar
Do a search on valvetrain weights chart, Brian Tooley from TEA posted this chart about 2 weeks ago,has all the weights on it.Nothing lighter then ls6 valves..Maybe pure titanium.
Old 08-18-2004, 02:39 PM
Thanks!
Old 08-18-2004, 02:42 PM
MyLS1Hauls's Avatar
You'll pay an unbelievable price for Ti valves...youre lightest most affordable option would be LS6 valves, but they are stock sized. As long as youre not building an 8500 rpm motor, Manley or Ferrea stainless valves would be fine with good springs.
Old 08-19-2004, 12:38 AM
FASTONE's Avatar
I guess you found that chart?Your"e welcome!
Old 08-19-2004, 01:16 AM
JoeDirt's Avatar
How much would it hurt performance if you had a set of ls6 heads worked but kept the stock sodium filled valves ?? It would be matched with a 224 220 581 581 116 cam.
Old 08-19-2004, 01:24 AM
FASTONE's Avatar
The stock diameter valves seem to work good in the 346 due to the smaller bore,you won"t gain that much with 2.02 and 1.6's.Smaller valves in small bore =less valve shrouding therefore better flow,that why heads flow more on a larger bore when tested,less shrouding.
Old 08-19-2004, 01:30 AM
JoeDirt's Avatar
So no real gains with ported heads if I keep the ls6 valves ??
Old 08-19-2004, 11:07 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
http://www.totalengineairflow.com/te...ainweights.php
Old 08-19-2004, 08:08 PM
Yup, thanks again guys
