HELP! Oil shooting out of breather!
I took my car to the track and made a few passes. The car was smoking real bad so when I poped the hood there was oil all over the pass side header. The breather I put in the valve cover was soaked with oil and was leaking down on to the header. I also had a bunch of oil on the floor of my intake. My motor has 500 miles on it, has a LS6 pcv system and a fast 78mm intake. What could be causing this?
I would do a leakdown test. Possible the rings are not seated yet, but current technology rings seat pretty quick if the cylinders were honed to the proper finish. There is also not a whole lot of vacuum in the intake at WOT/high rpms tp evacuate the crankcase through the pcv system. Have you consulted the engine builder, or did you build it yourself?
Originally Posted by 99midnighthawk
What would cause this? The motor is new. Could this be why I have no top end power?
