What do you think of this Cam w/a Stoker Motor?
Old 08-19-2004, 10:35 PM
Xtreme57's Avatar
Default What do you think of this Cam w/a Stoker Motor?
ok, i'm definintely getting a stoker short block for my car, i'm just not sure from where yet (cracked piston or block - dealer diagnosis) so i started thinking dangerously - "well, as long as i have the block out..." i decided to look into getting a cam put in w/it.
the cam that i like the best so far is a 224 - .581/.581 112 OR 114 (can't decide which yet) - my heads will remain stock for the time being as i CAN'T drop more $$$ to get them done too. What do you guys think about this cam w/ either a 383 or 395?
Old 08-20-2004, 12:09 AM
FASTONE's Avatar
It would be very streetable with a stroker, but you could go to a 230 if you want more power,get close to .600 lift.If you really want crazy go 236 on 113 or 114 LDAor 112????
Old 08-20-2004, 06:15 AM
jrp
SN95 Director
jrp's Avatar
hmm, big cubes + small cam + plus stock heads. dont expect much.
Old 08-20-2004, 07:10 AM
PREDATOR-Z's Avatar
Check out the R1 cam at MTI. Good for strokers.
Old 08-20-2004, 07:59 AM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
i had a 232 236 in my 395, lets just say it lasted as long as a dyno tune.
my 242 242 595 595 112 lunati is perfectly streetable with a 395 stroker
Old 08-20-2004, 10:42 AM
DAPSUPRSLO's Avatar
That big stroke is going to want more overlap to be optimum. Also, a bigger cam can help produce more air from stock heads. I'd say something in the .60x lift range on a 246/258 ish size with a 108lsa. You are crutching your self with stock heads but the increased overlap will help produce large flow from them. This cam shouldn't have too bad of an idle either in a 4 inch stroke motor.
Old 08-20-2004, 11:06 AM
WS6snake-eater's Avatar
How about a G5X-3 in a 408... Stage II ls6 heads...how would that do?
Old 08-20-2004, 02:56 PM
DAPSUPRSLO's Avatar
It would do alright but you need more cam to make the most power that this combination is capable of. There is a big difference between a 346 and 408, both in bore and stroke.
Old 08-21-2004, 12:10 PM
Xtreme57's Avatar
Ok, i'm leaning towards a aluminum 383 w/eagle internals. the heads will only be stock for a couple months so i can pay off some of the block before i get to the heads. The car is a daily driver, so i am looking for the most streetable power i can get w/o sacrificing too much low end or drivablility. Now that i think about it i heard that cam was good w/ stock motor, but i guess things would be different w/ a stoker. So what do you think would be a good streetable cam for a 383?
Old 08-21-2004, 06:24 PM
someday's Avatar
how about MTI's new G1? they used that cam in the 455GTO that made well over 500rwhp...
Old 08-23-2004, 02:08 AM
Xtreme57's Avatar
any idea what the specs are on that cam?
Old 08-23-2004, 02:48 AM
jrp
SN95 Director
jrp's Avatar
228/232 .5xx/.5xx 113. go to MTI's site for the lift number.
Old 08-23-2004, 03:26 AM
PREDATOR-Z's Avatar
228/232 ,.588/.575 113
Old 08-23-2004, 06:45 AM
SAM98WS6's Avatar
242/250 .595/.595 109 is streetable.
I wouldnt go less than 240+ on a 112 or 114
224 is way too small.
Old 08-23-2004, 04:51 PM
Xtreme57's Avatar
Sam,
what kinda cam are you runing w/that motor and what kinda numbers are you puttin down? that motor sounds like a beast
Old 08-24-2004, 07:56 AM
SAM98WS6's Avatar
Erson from Rapidmotorsports
specs as listed with 1.75 rockers
480rwhp/440tq
~stock compression LS1 Rapid heads
Nothing exotic..92 octane
steel driveshaft, stock wheels, and no tricks.
daily driver that sounds pro stock.
Cant imagine what Rapid LS6 heads and 11:1 or more compresion would do????
Old 08-25-2004, 01:48 PM
Xtreme57's Avatar
Sam,
DAMN those are some sick numbers!!
you running LTs too or what exhaust you got?
how well are those heads ported?
what compression you running?
why the 1.75 rockers?
what are the specs on your cam?
sorry for all the questions i'm just gettin really pumped up seeing what my car could be like when i'm done w/it.
Old 08-25-2004, 01:51 PM
Xtreme57's Avatar
oh just caught the stock compression, my bad. that's how excited i am lol!
Old 08-28-2004, 01:49 AM
Xtreme57's Avatar
so i'm thinkin about 234 .581/.581 113 what do you guys think?
Old 08-28-2004, 08:40 AM
383ss's Avatar
I think you should buy my 236/232 .602/.575 112lsa great for my 383 for a daily driver/drag car. made damn near 500rwhp with it and is VERY streetable.
