Oil port
Old 08-23-2004, 05:12 PM
t1z06's Avatar
Question Oil port
I plan on adding an accusump and I have heard there is a port on the drivers side front of the block. Can someone confirm this and if you have any details such as thread size.
Thanks
Old 09-24-2004, 12:43 PM
RX-Ben's Avatar
up...
Thanks
Old 09-25-2004, 03:52 PM
2001CamaroGuy's Avatar
Thanks
don't know what you mean by "port"......
I just "T-ed" my accusump into my oil lines that run from my oil cooler.....
Old 09-29-2004, 12:46 PM
RX-Ben's Avatar
A port as in a spot directly on the block where the Accusump can be plumbed into. Like a fitting that lead to the oil galleys.
Old 09-29-2004, 01:18 PM
RX-Ben's Avatar
I found this:
You can feed into the oil galley plug behind the PS pump, it's a 16x1.5mm threaded port. Earls etc. have adapters to go in there.
