What length pushrods do I need???
I had my stock LS1 heads hand ported rather extensivley(did not mill heads), put some Patriot dual springs, Comp cams oem replacement lifters, still the ole Hotcam and LS6 valves. Can I still use the 7.400 hardened pushrods I have or do I need something shorter? Thanks!
Originally Posted by YOOFORMULA
Even if the valves are longer in length? This is the only thing i can think of thats causing the chattering I am hearing once the motor gets warm.
So to cure your chattering you need 7.35 p-rods. right now you have too much preload and your lifters are bottoming out. (Could collapse)
Hope this helps.
Originally Posted by technical
Ahh, didn't get that from the original post. Sorry 'bout the confusion.
