408 or 427
408 or 427
so should I go with a 408ci or 427ci with my 6.0 block I know there is a couple 408ci kits out there but I haven't seen any 427ci. what a the drawbacks to a 427ci motor, the 4.125 bore?
You can do many different sizes with a 6.0 Iron Block
402 = 4"bore x 4"stroke
408 = 4.030 bore x 4" stroke
414 = 4.060 bore x 4" stroke
422 = 4.030 bore x 4.125 stroke
427 = 4.060 bore x 4.125 stroke
These are off the top of my head, they should be correct
I have an iron block So the bottom of the block needs to be machined as well. That isn't to bad, worth the effort? I think It would be, I mean I like torque. So there's no problem with 427ci other than the bottom machine work? I was thinking the boar need to be 4.125 that's kinda thin, but I can live with a 4.125 crank stroke. SO is there enough room in the piston for the pin and the bottom oil ring? Or what? What pinston and what connecting rod?
