Torque Numbers for H/C
Hello
I want to do a heads and cam pkg. I already have the big G5x3 cam. What kind of torque numbers are you guys seeing. And what heads are you using.
thanks
thanks
Without flycutting pistons, stock heads! (G5X3 on 114lsa)
http://www.ls1howto.com for all the install specs and directions.
Originally Posted by goober35
I dont think he cared about install secne he said he already had the cam. Not sure if he has it in though. You might see 380rwtq Not sure do a search.
Thanks for the site, it seems to have a lot of useful info. What I am looking for is what can I expect rw torque from adding a good set of heads like the AFR. I already have the x3 cam installed 04 Z06 I got 429/395 rw. I am hoping to get around 440-450 rw torque, I just want to see if this is possible.
Thanks
Thanks
Thanks
Thanks
Thanks
Just hand over your LS6 heads to TEA or AS and get them worked on. I wouldn't swap LS6 for AFR, much cheaper to port.
