Motor Setup Help
Are you looking for the stock motor with just different heads/cam or replacing the motor and stroking or boring it?
you can run mid 11's with cam only if you have the right setup.
by the right setup, you need all bolt ons, including tb, pulley, headers exhuast/ypipe or true duals, and a solid suspension with traction. traction will be your biggest foe.
my 98 z28. Im not shure if i wana use stock short block or stroker. how hard whould it be to get 11.5s outa a stock short block. ... also whould it handle enought spray to get me in the 10s
