tsp 231/237 /heads questions
Old 08-28-2004, 10:08 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
Default tsp 231/237 /heads questions
i'm planning to buy this cam is there going to be any P/V problems with stock heads. and can i use after market milled heads with it or do i have to clearance the pistons. i'm planning to but stock ported heads or is it better to buy aftermarket. thanks guys
Old 08-28-2004, 11:56 AM
SS SLP2's Avatar
Running 231/237 with stock heads, no problems, do not know about aftermarkets, with LT' and cam cut .8 off in 1/4
You will be happy.
good luck Johnny
Old 08-28-2004, 08:01 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
5.3L heads or welded chambered 6.0L heads work well with this cam. Both offer higher compression without milling.
Old 08-29-2004, 02:14 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Call Jason or Trevor at TSP and they'll help you pick the right combo. Many run that camshaft with bigger valves and even a little milling. Ask them about the enw Precision Race Component heads
-Matt-
