Rocker Arms
Old 08-30-2004, 04:48 PM
ProStreet_632's Avatar
Default Rocker Arms
Any real benefits and gains going from a stock rocker arm to a non ajustable roller? If so what can be expected power wise and what is a good brand to go with.
Old 08-30-2004, 04:57 PM
PREDATOR-Z's Avatar
Less valvetrain noise,
Less friction
Better valve centering at point of V contact
Less binding
less twisting, none if they are shaft
perhaps a few more ponies?
Less chance of getting bearings in your oil pan
Old 08-30-2004, 06:47 PM
mrr23's Avatar
well the VHP 1.89 accelerated lift rockers are the adjustable type. but here's dyno graphs anyway. tq peak isn't right there was a spike at the beginning of the run.
Old 08-30-2004, 07:30 PM
WinMan's Avatar
Sry to take your thread, but I have a set for sale in the parts forum. They are Harland Sharps 1.8 ratios which are the better of the aftermarket rockers (besides jessel). I paid 300 for them on sale. I will let them go for 250. Let me know.
Old 08-30-2004, 07:31 PM
WinMan's Avatar
nvm, sry. They are sold
Old 08-30-2004, 07:44 PM
RX-Ben's Avatar
[QUOTE=mrr23]well the VHP 1.89 accelerated lift rockers are the adjustable type. but here's dyno graphs anyway. tq peak isn't right there was a spike at the beginning of the run.
Going from the factory 1.7 ratio to a 1./9- you are going to get longer effective cam duration which could account for much of the power gains. Does anyone have any graphs of a back to back pull between the stockers and a set of aftermarket 1.7 rollers?
Thanks
Ben
Old 08-30-2004, 09:54 PM
cyphur's Avatar
PZ hit it right on the money. I just picked up a set of slightly used YT 1.7 shaft mount roller tip roller rockers. I expect very little for hp gains(might be a few peak, but I won't know, since they'll be installed same time as cam install, 231/237). What I do expect is strengthened drivetrain. More rigid. Definitely more reliable. My car has 62k miles on it, and putting a cam in it, I did not want to risk finding a **** load of bearings in my oil pan when I go to put heads on her in the winter/early spring. This should definitely help me avoid that. Pick you up a set of used rockers, I got this set and they could pass for new. They apparently have 2k miles on them...but you couldn't tell. Its a good insurance policy. Between these, the chromemoly pushrods, and PP Gold Dual springs...my valvetrain will be good to go. Then I'll just have stock lifters!!
Old 08-31-2004, 08:24 AM
killer01ws6's Avatar
Less friction
Less binding
Not to mention, My HS Rockers are almost to nice to put the valve covers back on.
They are purty
Old 08-31-2004, 11:37 AM
Buckshot's Avatar
Can anyone tell me where to buy Harlan Sharp 1.7 rockers? I've been trying to source them with no luck.
TIA.
Old 08-31-2004, 12:58 PM
RedHardSupra's Avatar
Nate at Nasty Performance in Chicago burbs been great with both price as well as support, go find it in sponsor list -->>
Old 08-31-2004, 01:03 PM
PREDATOR-Z's Avatar
TSP>>>>>>>>>>>>>>>>last quote they gave me was $320.00
Old 08-31-2004, 01:04 PM
Buckshot's Avatar
Thanks. Appreciate it.
Old 08-31-2004, 01:24 PM
WAHUSKER's Avatar
Not sure you will see any gains going with the 1.7 rollers. Mostly piece of mind. I gained 15rwhp with the 1.8 HS rockers (bought them from Nasty). And then 21 more when I stuck a Hot Cam under them!
Old 08-31-2004, 05:02 PM
Black Z/28's Avatar
I just finished installing mine (HS 1.8s). On my stock cam, the RRs were also pretty quiet (quieter than the stock rockers). I'm scheduled for a dyno in 2 weeks, I'm curious to see if I picked up any decent peak hp.
Old 08-31-2004, 11:46 PM
lsx24's Avatar
Oh man I almost bought a set of 1.7's for a CompCam.
