air to fuel gauge install
i want to install and air to fuel gauge on my car, but dont know where to hook up the wire that reads the air to fuel. And where is that wire located, and whats the best way to hook it up.
Guest
Posts: n/a
Originally Posted by MyLS1Hauls
Whats the point of using an A/F gauge with the stock O2 sensors? They arent capable of reading A/F outside of stoich. I guess the gauge looks pretty with all of the lights.
The stock O2's are narrowband, they aren't going to give you any useful information really, unless it's too late...
If you're going to do an A/F gauge, consider a wideband that used a wideband O2 sensor that you would install using a new, weld-in bung.
Originally Posted by 2MuchRiceMakesMeSick
You mean that you cannot use the bung (hole ) that comes with the jet hot long tubes?
