Crank Seal Replacement
I need to replace the front crank seal on my 99 T/A. I've been told several different things about what all needs to be done to replace the seal. Is it true that all I have to do is pull the crank pulley off to get to the crank seal? Do I need any special tools to remove and reinstall the crank seal?
Not supposed to lube the new seal. Install it dry.
You'll need a new crank bolt from the dealer too. Go to www.ls1howto.com and look up the cam install procedure. It'll have what you need for the crank seal.
