Will this cam and head combo work?
Patriot LS1 CNC Stage II heads complete heads and the LS1 Grand-Am Cup, 239/251 Duration @ 0.050, Racing Camshaft
power expectations with full exhuast and an 80mm TB?
http://www.fbodymotorsports.com/inc/...l?v=1&pid=8141
http://www.fbodymotorsports.com/inc/...l?v=1&pid=8851
Definitly not a street cam (Unless you're in Aussie Land) 106 lsa would be serious racing only and would require some massive flowing heads.
Head choice is allright but I would go with another cam for sure.
Give us some more info about your car, mods, purpose of H/C swap, street/strip, strip only.....etc..
I think it was some guy that worked at scoggin dicky(GM parts sponsor to the left) that ran that can in a Z06 I think and it was maybe daily driven. Its not really nessarry to go that big on the street unless your doing a bunch of freeway run. (that cam makes a ton on the top end) but you will have to run gears with it to gain drivability. Whats your HP goal's because you can mostlikley go smaller and get what you want with better street maners.
PZ, why can Aussie's run bigger cams? And whats with the maffless tuning? Why do they get away with that ****? Something with them being in the southern hemisphere? LOL. I'm lost....or is it just cuz they're nuts down there....with no real scientific reason....??
this car is gonna be a daily driven z28, with a 80mm TB, the patriot stage II heads, hooker long tubes with a cat-less y pipe with magnaflow or borla cat back. and then a cam, and im also unsure about what chip or tuning i should get. also if ill need to upgrade my fuel system. i might also get nitrous if i still have money.
for power gains, id like to compete with stock and lightly moded 03 cobra's, so id like the power around 475
ps. even tho its gonna be daily driven, i want a really lumpy idle, i want the big cam sound.
****. if you want 500 hp you're gonna need more then just heads and cam. you're gonna need nitrous or a SC/turbo. but back to the cam. thats a big freakin cam, much larger then you'll need to go. i'd say you could get away with something like the TSP torquer(233/233), tsp magic stick(237/242), T-ReX (242/248) maybe. any of those cams will give you at least 45hp, the second two will probably give you 50hp or more. Also, I'd suggest running LS6 heads if you want to see 450rwhp. You won't be able to get them milled if you go with the second two cams I suggested due to Piston-To-Valve clearance issues, unless you notch the pistons. Which you may want to do, if you want to up the compression(good for some more power).
You can't run the T-rex with bigger valves unless you notch the pistons. It was set-up to run the tightest P/V with stock heads. Any alteration from that will cause clearence issues. As for the tuning, our cars can be tuned to speed density/mafless. It isn't hard, you just have to have someone that knows what they are doing.
have you read jrp's cam guide? if not, find one of his posts, and read it. its in his sig. that will explain most of what you'll need to know. then you'll need to read some posts in the internals section concerning heads. there's been a TON of talk in here lately about heads, so there should be no lack of reading for you. nobody is going to be able to sit you down and tell you exactly what will be the best combo for you....only you will be able to figure out what will fit you best. only you know exactly what you want the car to do, how you want it to behave, what kind of numbers you want it to make, how you want it to handle, how long you want it to make the kind of hp you want, where you want the torque, all that stuff. these are all things you need to figure out. i researched this **** for five months before i figured out what cam i wanted to get. i read jrp's cam guide prolly four times before i started asking questions. i still read it just to learn more. keep reading, see what has worked for other people, find people that are trying to do something similar to you, see what they did, or didn't do. ask them questions. call a few sponsers, talk to them about it. you can't just post up and expect someone to spell out a combination. everyone will tell you something different, because everyone will have their favorites.
personally, i think you should look into a strong custom cam, somewhere in the 236/242 on a 110 lsa with a good set of stage 2 or 2.5 ls6 heads. get all of the bolt-ons(asp under drive pulley, long tube headers, lid, ls6 intake(if its a 98-00), ported throttle body, good exhaust, electric water pump maybe). if you're an automatic, get a good and high stall, say a 4000, maybe a 4400. if you're a m6, get a good clutch. either way you'll need a 12bolt or a 9inch rear end.
there, you at least have my opinion. hopefully others will add in theirs. this should give you somewhat of a start. go search. as jrp would put it, USE THE ******* SEARCH BUTTON. its your friend. good luck.
Yes you are reading correctly! 1 TB/every cylinder.
I heard a clip on a Holden with a 106 lsa cam that idfed like a 224/112lsa, even better.
Originally Posted by PREDATOR-Z
Well besides speed/density tuning, they run independent TB/intake combos.
how do they pull that stuff off? and why don't we get this stuff? this isn't fair LOL. I've been to Austrailia, when I was still in high school, that place is freakin awesome. i wanna go back. they rock down there.
I've been wanting to go there myself on a 2 week LS1 schooling trip.
Originally Posted by BatmanLS1
I was down there on a study abroad. I saw 1 Mustang Cobra, 1 Corvette, and 10000 Nissan Skylines.
Yeap I know the feeling, got to admit some all wheel drive ones are pretty impressive though. I know a couple here that run 9.5, but these are gutted track cars. On the Street, I whip their butts.
The best part is from a dig and then you hear that clutch disintegrate
nissan skylines are pretty sweet cars....thats one of the few imports i'd actually drive. of course it'd be the car i'd park on the curb in the dirt while the ls1 sits pretty and clean in the garage....but thats not the point.
