Whats it take to have machine shop retap for 1/2 head studs?
Im interested in having a local machine shop redo my block for 1/2" studs which alot of the big blower/nitrous guys seem to move to when they cant keep the heads down....
How much would i expect to pay?? also anything special about it they should know or i should make sure they know before they try it.
Also i figure ill have to have the heads drilled for 1/2" as well?
LS1TECH Sponsor
Block rethread
Just make sure the new threads are roll formed and not cut with a tap. The roll former compresses the metal greatly increasing the strength of the aluminum threads in the block.
An alternative would be to use the stock diameter studs but order them from ARP with their stronger material.
I included in a post last night on the forced induction page a bit about heads lifting. The cause is detonation. I have seen heads lift with half inch studs on iron Nascar Ford blocks that had too much timing, ran lean or both. Something is going to give under detonation the heads lifting are acting as a safety valve.
Steve Demirjian
Race Engine Developmet
Sponsor
Steve Demirjian
Sponsor
Hmmm very interesting and thank you for the imput...I never thought about detonation as the cause...maybe ill just order the stronger head studs and see where i get from there..thanks
