comp magnum 7.5 rocker ?
Old 09-07-2004, 11:38 AM
silverZ98's Avatar
Default comp magnum 7.5 rocker ?
yes i whould like to know what the lift whould change to with the comp magnum 7.5 rockers. i am running a tsp 231/237 595/598 lift cam and cran double valve spreing rated ot 650 lift. and do you guys think id be safe to try this? thanks
Eddie
Old 09-07-2004, 11:44 AM
SAM98WS6's Avatar
If your lift is with stock rockers (1.7) then you will only add .05 more lift with 1.75. .613/.617
I would get rid of stock rockers no matter what. You will have to clearance the valve covers and check geometry.
Old 09-07-2004, 12:07 PM
PREDATOR-Z's Avatar
actually it is .613/.616 (not that it makes a dif.)
But I wouldn't do that IMO. If you are desperate to change the rockers the try HS 1.7's or wait a little while and Nasty Performance will have a C-clip upgrade kit for stockers pretty soon
Old 09-07-2004, 12:14 PM
silverZ98's Avatar
thanks guys im wanting ot go to adjustbles with out breaking me thats why i was looking at the 7.5 magnums. so i wanted ot get some in put on the idea
Eddie
Old 09-07-2004, 05:02 PM
z-ya's Avatar
Pro magnums have been used in some very high zoot setups with excellent success.
Old 09-07-2004, 05:47 PM
max's dad's Avatar
I'll be using the same TSP 231/237 with the comp 1.75s. I'm waiting on AFRs with Patriot doubles that should have been sent last week. I'm hoping to have eveything together and dyno tuned within two weeks.
