pushrod and milled heads
Old 09-07-2004, 07:19 PM
jason5's Avatar
Default pushrod and milled heads
i'm rebuilding the motor, i have heads and cam, 230/230 591/591 110, cam and heads are milled 35 thousanths, has anyone used this simialar combo and i'm trying to deciede if i need a shorter pushrod than stock length and what length should i use, also another question i have been using comp 918 springs, with a 591 lift cam, are these good springs for 591 lift i know they are rated at 600 should i got with stronger spring or are those strong enough thanks
