Low lift (sort of) & a little longer duration???
Old 09-09-2004, 08:12 PM
Dragula's Avatar
Default Low lift (sort of) & a little longer duration???
Does anyone make a cam with 230 / 230 .550 / .550 on 112 or 114 lsa?
Comp doesn't list anything like this in their catalog.
TR jumps from 224 to 240 with the Trex with high lift.
I want a cam that will be easier on valve springs.
I wouldn't even mind 226 / 230 .550 / .550
Old 09-09-2004, 08:31 PM
technical's Avatar
You might be interested in the GM ASA cam. Specs:
Duration @ 0.050" (I/E):226/236
Lift (I/E): 0.525"/0.525"
Lobe Separation: 110
Maybe some 1.8 rockers will get you the lift you're looking for.
Old 09-09-2004, 08:36 PM
marc_w's Avatar
I'm willing to bet you can get one custom ground through a number of sponsors... but I haven't heard of an off-the-shelf cam with those specs.
Old 09-09-2004, 08:48 PM
Dragula's Avatar
I like the ASA cam but I'm concerned with the LSA.
Old 09-09-2004, 09:05 PM
marc_w's Avatar
Comp has a 228 lobe with .537 lift... in the first section here...
The next 228 lobe 'up' is at .572 on the lift. (XE lobe?)
Old 09-09-2004, 09:12 PM
technical's Avatar
That comp 228 is a nice cam, plus the LSA is smoother. You'll probably want to stay away from the XE lobe if you're concerned with valvetrain punishment.
Old 09-09-2004, 10:03 PM
Another_User's Avatar
You could always get the cam with the duration you want and get a set of rockers to up the lift.
Old 09-09-2004, 10:06 PM
44mag's Avatar
dont worry about the 110 lsa it drives perfect as long as you get it tuned!!!!!!
strong cam has alot of potential.
Old 09-09-2004, 10:48 PM
V8er's Avatar
Excuse my ignorance, but is the idea behind less lift with long(ish) duration to make good top-end power will less valve spring stress? With all the talk of broken springs (singles and duals) this sounds like a great idea.
Old 09-10-2004, 10:26 AM
technical's Avatar
*Generally* speaking of cams, more lift can build more power without affecting the powerband too much. The drawback is valvetrain stress. More duration also makes more power, but will shift the power band up the rpm's a bit sometimes costing you some low end power.
Old 09-10-2004, 10:38 AM
Blue Hawk's Avatar
Lunati LUN55007: 230/237 .544/.543 112 +4
Old 09-10-2004, 02:02 PM
gollum's Avatar
www.reedcams.com has LS1 cams.
Old 09-10-2004, 02:10 PM
cyphur's Avatar
1.75's would put you at .540, 1.8's would put you at .556(rounded up).
Old 09-10-2004, 06:02 PM
Dragula's Avatar
I noticed the comp 224 / 228 .534 / .537 112cam after I posted this message. I like that design.
The Lunati LUN55007: 230/237 .544/.543 112 +4 looks good too.
Yes thats exactly why. I know I'll move the powerband up but hopefully not to far.
Does anyone know what RPM peak HP will occur for the Comp cam listed above, it will be used with longtubes?
I don't want to change the bottom end at this time.
Old 09-11-2004, 02:13 PM
technical's Avatar
You'll probably see peak hp ~6k give or take a few...the lunati will more likely make peak hp at ~6300 but those are just estimates.
