Anyone using the Rev dual valvesprings for stock valve pockets?
REV Dual Valve Springs, 1.25" OD (For stock spring pocket) Must use with 54-SC221 Hardened Seats & 54-TR9814 Titanium Retainers
Just curious if these are a better way to go over the Comp 918's for a lift of about .56x. If they are do they just drop right in?
Thanks,
J.
Thanks,
J.
Re: Anyone using the Rev dual valvesprings for stock valve pockets?
I am also running the Rev 1116 Dual Springs. No machining was needed, so far no problems. I have put about 2000 miles on my car with the springs and 5 runs at the drag strip.
<small>[ April 02, 2003, 12:13 AM: Message edited by: Mitch ]</small>
i bought these but have not installed them yet. i assume you also bought the new valve seals since they do not come with the new hardened seats.
The Bull
I've installed a set of these on a car with a .581 lift. Very nice setup, fit in the pockets nicely. You will likely want to get new stem seals. You could reuse the ones that you pull off, but just to be on the safe side just pick some up and replace them. You can see pictures of the install off my website under the C5 Cam Swap.
REV 1116 dual springs with West Coast Cylinder Head's Titanium Retainers/Hardened seats. I used new valve seals and did not have to do any machining/modifying to make them work. 7000 hard miles and 3-4 harder trips to the track on the current set. Using 224/.581/112 cam here.
I plan on going back with another set of these springs in 3-5 months when I freshen the valvetrain up. Maybe a bit more aggressive cam.
Whats the downside to using rev 1116 springs?
compared to 918's?
Why don't more people chose the rev 1116 dual springs ?
If its cost? how much more expensive would it be than 918's?
Is it noise? Is it performance or durability issues?
Is it tougher to install to the exacting standards with the heads on the car?
What about timing chain? Is that something to do? if so how much more is something like that and is that a good idea?
Thanks in advance.
JB
<small>[ April 02, 2003, 10:25 PM: Message edited by: JBsC5 ]</small>
compared to 918's?
Thanks in advance.
JB
The Bull
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FinalTA:
<strong> Derty--
Your C5 cam swap page isnt working right...FYI </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's fixed now. Sorry about that.
<strong> Derty--
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JBsC5:
<strong>What about timing chain? Is that something to do? if so how much more is something like that and is that a good idea?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll let someone else comment on 918s vs 1116s (I have a set of REV 1116s myself), but a good timing chain is always a good idea with a cam swap. Rollmaster is a very good, cheap chain...I have one of them too. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
xaon: Are the West Coast Cylinder Heads retainers the same ones that A&A Corvette sells, or are those different?
<small>[ April 03, 2003, 08:05 AM: Message edited by: J'sRamAir ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Whats the downside to using rev 1116 springs?
compared to 918's?
Thanks in advance.
JB
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not sure about a downside as there are quite a few using the REV 1116 springs. They cost about the same as the Comp 918 springs. Some customers have logged over 35000 miles so far without fail. Our spring kit is designed to install on stock heads without measuring anything. The kit can be installed without removing the heads and can easily handle cams with .600"+ lift.
I strongly recommend installing a new heavy duty timing chain during the cam install. The chain sets range from $140 to $180 depending on which set you use.
Good luck,
Richard <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
compared to 918's?
Thanks in advance.
JB
Good luck,
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by J'sRamAir:
<strong>xaon: Are the West Coast Cylinder Heads retainers the same ones that A&A Corvette sells, or are those different? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Same ones that A&A Sells, I purchased mine from A&A.
Not really sure on the downsides between the REV's and the 918's. Though there is some added peace of mind (in my case at least) with the REV's.
I would most definately upgrade the timing chain. I went with a rollmaster double roller in my car.
Also, the REV 1116's are the only recommended springs for the big (240 @.050, .609" lift) G5X-2 cam on stock heads from LG Motorsports.
I have the REV duals for my G5X1.
For a cam as you stated (.56x) lift, i'm sure the 918s would do the job just fine.
Im running the revs for about six months now with thunders 224 561 112 cam. Have about 6000 miles on them and approximately 20-25 passes. There a great spring and I have had no problems. There a guy up here in minnesota who is running them on a ASA road race motor that lives at 6500 rpm and he stands behind them too.
Thanks guys...I believe the rev 1116 dual spring gives you added safety and costs and installs just about the same as the 918's. Its not a harder install..it doesn't rob any power and lasts just as long between maintaince intervals
Why wouldn't everyone use the dual rev 1116?
Is it harder on the drivetrain? Does it make more noise?
I don't get it. It seems it would be a slam dunk to buy just for the fact you don't have to worry about spring breakage...(having in the past been the one weak link to cam installs with other springs)
Thanks for the advice on both the cam/spring/timing chain choices.
The Bull
I thought the REV was a nice setup. However just like the 918 there have been some small instances of broken REV's as well. Overall it's going to be a nice setup.
What are the specs on each of these springs. Seat load @ height, load at lift, spring rate, coil bind height?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Larry:
<strong> What are the specs on each of these springs. Seat load @ height, load at lift, spring rate, coil bind height? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Here you go: https://ls1tech.com/ubb/cgi-bin/ulti...;f=41;t=006940
Will these dual springs work on my Agostino stage 2 heads? I bought the heads about two years ago and most double springs wont fit without machining. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Will these dual springs work on my Agostino stage 2 heads? I bought the heads about two years ago and most double springs wont fit without machining. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The REV dual springs will fit into all LS1 heads. Deciding to use them depends on your cam choice.
Good luck,
US Troops Rock!!!
Good luck,
US Troops Rock!!!
