Oil Analysis came back!
Old 09-14-2004, 01:10 AM
pimpmaro's Avatar
Default Oil Analysis came back!
I don't have a scan of it or anything, but if anyone's interested, I figured it might be a good idea to try and get some oil analyses up for people to look at and compare to their mods. Maybe some people other than just Patman will be interested...
Oil was Mobil1 0w40....
Elements in ppm Unit #'s LS1 Averages
Aluminum 2 , 4
Chromium 1 , 1
Iron 6 , 14
Copper 9 , 42
Lead 4 , 7
Tin 0 , 2
Molybdenum 65 , 56
Nickel 0 , 1
Manganese 0 , 1
Silver 0 , 0
Titanium 0 , 0
Potassium 0 , 1
Boron 129 , 80
Silicon 4 , 9
Sodium 6 , 8
Calcium 3091 , 2143
Magnesium 13 , 487
Phosphorus 815 , 748
Zinc 869 , 893
Properties
SUS Viscosity @ 210*F:
Should be -> 65-76
Were -> 68.5
Flashpoint in *F:
Should be -> >375
Were -> 375
Fuel %:
Should be -> <1.0
Were -> <0.5
Antifreeze %:
Should be -> 0
Were -> 0.0
Water %:
Should be -> 0
Were -> 0.0
Insolubles %:
Should be -> <0.6
Were -> 0.3
Old 09-14-2004, 04:41 AM
Patman's Avatar
You forgot the most important info, how far did you run that oil for? If it's 3k or more, those numbers look pretty good.
Old 09-14-2004, 07:37 AM
pimpmaro's Avatar
Sorry about that! It was late at night and I was the most coherent at the time. Here are some more important #'s:
Miles on Oil - 3000
Miles on Unit - 54562
Comments: Nothing showed up in the initial sample from your Camaro that would indicate a problem. In fact, this is possibly the best wearing LS-1 I've seen all month! All wear read at or below averages, which is a very good indication of normal wearing parts. Universal averages show normal wear after about 3,900 miles on the oil. Insolubles (oil oxidation due to heat, use and blow-by) were low at 0.3%, showing good oil filtration. No fuel dilution or anti-freeze was found. At 54,562 total miles, this engine appears to be doing very well.
Old 09-14-2004, 07:41 AM
pimpmaro's Avatar
One thing I noticed was that the viscosity and flashpoint are both towards the bottom end of the spectrum. After only 3000 miles, it's making me consider switching to Amsoil or Redline... Any thoughts?
Old 09-15-2004, 07:32 AM
Patman's Avatar
The viscosity of 0w40 Mobil 1 usually does dip down a little bit in the first 3000 miles, but then it comes back up again after that. The flashpoint does look a little low, although some of that reason is the 0.5% fuel in it too. I would stick with this oil for a little while since it does seem to be working well, the wear numbers are good.
Old 09-15-2004, 08:14 AM
silverZ98's Avatar
where can i send some of my oil to get this test done?
Old 09-15-2004, 09:30 AM
pimpmaro's Avatar
Sent you a PM...
Old 09-15-2004, 09:58 AM
Devilss02's Avatar
Hey pimp, could you also send me a pm so i can see where to send my oil. thanks
Old 09-15-2004, 10:08 AM
silverZ98's Avatar
thanks man got it
Old 09-15-2004, 12:46 PM
Race your car!
JL ws-6's Avatar
Please P.M. me the info on getting the oil checked out, I am curious as to how my car's doing too. Thanks.
Old 09-15-2004, 12:56 PM
Hysteria's Avatar
Also try Royal Purple.
Old 09-15-2004, 07:57 PM
pimpmaro's Avatar
Devil and JL... Pm's sent. =)
Old 09-15-2004, 09:40 PM
Ojustracing's Avatar
Sample looks good. But what were the driving condtions. Highway, stop/go and how much racing if any. John
Old 09-15-2004, 09:42 PM
Boostaholic's Avatar
How much did this test cost?
Old 09-15-2004, 09:45 PM
pimpmaro's Avatar
Driving conditions for that particular test were basically all highway, next oil change will be analyzed too, it's a lot more stop and go.
Test cost $20, add $10 if you want a TBN (total base number) count. That can give you more information on extended interval usage.
Old 09-15-2004, 09:47 PM
Jammer's Avatar
Ok Oil guys... What do you like for a twin turbo??? Synthetic I assume. I am just finishing break in so Ive run reg oil twice, and Castrol SynBlend twice...time to find a place called home... Amsoil??
Old 09-15-2004, 10:02 PM
pimpmaro's Avatar
Well I'm no oil expert at all, I would wait for Patman to make an appearance. He seems to have done the most research on the subject out of just about anyone on the boards. However, what I'm running now is Mobil 1 and you can see the wear #'s I got on my oil analysis. I was very happy with them. On the other hand, I'm planning on trying Amsoil (which I've heard exceptionally good things about) or Redline sometime soon. These are just my opinions, and I'm extremely happy with the Mobil 1, but I can't say for sure about the others since I haven't tried them yet. Hopefully Patman will chime in sometime...
Old 09-16-2004, 04:31 AM
Patman's Avatar
With a twin turbo you'll probably end up running hotter oil temps so you'll want to run something like Redline 10w40, Amsoil 10w40 or Royal Purple Racing 41. Mobil 1 0w40 would also be good too.
Old 09-16-2004, 04:50 AM
98Zam's Avatar
please PM me please with info on where to get this done. thanks!
Old 09-16-2004, 12:58 PM
Terry Dyson's Avatar
Guys consider using our services for a extra $5 from the lab Pimpmaro used and I will interpret the data and give you essentially a tune up overview from the oil analysis data. That includes TBN too. If Pimpmaro will allow me I will give him a free online read for a good example of what can be done with analysis.
Terry
