Is everyone soaking their lifters and rockers in oil before assembly?
Old 09-15-2004, 10:14 AM
SAM98WS6's Avatar
Default Is everyone soaking their lifters and rockers in oil before assembly?
I still cant believe all the valvetrain issues here. I put together my first motor with the help of a buddy that has done big blocks before and I havent had any valvetrain issues at all...with comp Rs, Pro Magnums, and a wild *** cam.
Are you guys soaking the lifters and rockers in oil for a few hours before assembly? Wonder if that is causing you guys some problems...oil issues. Checking the roller tip on the retainers for pushrod length? Putting the recommended preload (.008-.010" for my setup)? I just saw another post for no preload with Pro Magnums..dont understand it.
Old 09-15-2004, 11:09 PM
LS1Tech Co-Founder
Nine Ball's Avatar
I have always soaked my lifters and pushrods, but not my rockers.
Old 09-15-2004, 11:22 PM
SSean's Avatar
Old 09-16-2004, 12:40 AM
jrp
SN95 Director
jrp's Avatar
i followed the instructions on my comp 850's and soaked them before installation. used a PR checker to check for the correct length.
Old 09-16-2004, 04:22 AM
DaleMX's Avatar
I Clean them with solvent then soak them in a coffee can.
Old 09-16-2004, 06:58 AM
SAM98WS6's Avatar
Yep, wash them to get the storage crap off...then soak them. Just wondering if these guys arent doing that and its contributing to the problem. Rocker tip on valve tip was easy to check too.
Old 09-16-2004, 07:20 AM
Camaroholic's Avatar
I like my coffee like I like my women (thick, strong, and very bitter ), but I wouldn't soak my lifters in it... that'd be a waste of good coffee...
(and I presoak my lifters in oil too... )
Old 09-16-2004, 08:38 AM
Super Moderator
Reckless's Avatar
I usually soak the lifters but not other parts.
Old 09-16-2004, 10:20 AM
FASTONE's Avatar
Good practice to soak roller rockers and rollerlifters in oil prior to installing,I would soak at least 24 hrs.Also a good way to store these parts when not in use.If you can get a plastic gallon container with a big screw on lid and put a qt of oil in it with your motor parts,works great.Don"t forget to label it so you know what parts they are.
Old 09-16-2004, 11:34 AM
Moderator
jimmyblue's Avatar
Used to be, you were supposed to put the lifters in oil
and work the center plunger so's they got the internal
fluid chamber filled. But that's hard to do when the
bottom isn't flat anymore....
Old 09-16-2004, 05:06 PM
technical's Avatar
I just spit on them...
Old 09-16-2004, 05:08 PM
FASTONE's Avatar
Had some fish for lunch!!!UM GOOD!!!
Old 09-16-2004, 05:09 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
I soak the lifters for a while.
Old 09-17-2004, 12:19 PM
SAM98WS6's Avatar
I was hoping some guys would chime in that didnt soak their rockers/lifters...and not have any issues or all had issues. Looks like all of us that dont have issues soak the stuff.
Old 09-17-2004, 01:09 PM
pekkaz's Avatar
I installed Crane stock replacements without soaking... no problems. Just cranked the engine without plugs to get oil pressure and pump up the lifters.
Old 09-17-2004, 01:33 PM
marc_w's Avatar
I agree here... I thought the only reason to do the oil thing would be to pre-pump-up the lifters.
Old 09-18-2004, 09:13 AM
SAM98WS6's Avatar
you have to wash them in mineral spirits to get the cosmolene off/out of the oil passages...then soaking them in oil get it where it needs to be right off the bat...in my opinion.
If you didnt wash them I would think the roller tip would have major issues.
Old 09-18-2004, 10:17 AM
66deuce's Avatar
i followed comps directions that came with my stock replacement lifters.(wash with mineral spirits then soak in oil overnight)no problems.
Old 09-18-2004, 12:49 PM
pekkaz's Avatar
I sprayed the roller tips real good with CRC and also sprayed through the oil hole. 7k miles on these now. Much faster this way, but of course if you want to play safe you go by the procedures.
Quick Reply: Is everyone soaking their lifters and rockers in oil before assembly?
