ok this may get messy
Who has proven to be the most consistant (in a good way) head porter to date? What i mean is who's heads flow pretty much the same from one set to another? I know i repeated myself, couldn't deside which one sounded better so i put both.
Once you are using a CNC program, you will produce nearly identical numbers between sets of heads. However, most porters finish the heads by hand, therefore introducing a chance of variation. Provided, you have competent people doing the finishing work, the numbers should be pretty close. I have seen certain sponsors on here admit that there can be errors in the hand finishing process, and that if you see that on a flow bench, you can send them back and they'll fix them for you.
Originally Posted by mdhmi
"Consistency is the hobgoblin of little minds". What about heads that are consistently bad? I would be inclined to get AFR, LPE, or MTI heads. I don't care about consistency. I care about proven numbers.
Mark
Mark
