2000 C5 vibration only between 800-1600 rpms
Old 09-17-2004, 05:56 PM
TT_Vert's Avatar
Default 2000 C5 vibration only between 800-1600 rpms
i can feel it in the shifter and in my feet/butt. Anyone have any clue what it could be? I dont notice it on accel but I do notice it when reving in neutral. Clutch in or out doesnt matter. Any in put is appreciated.
Thanks
dave
Old 09-17-2004, 06:39 PM
LS1TECH Sponsor
Textralia's Avatar
Thanks
dave
Did you recently have a new clutch installed? Wash
Old 09-17-2004, 06:40 PM
C5kid's Avatar
yeah same as wash guy, did you have a new clutch or flywheel installed, almsot sounds like that they are out of balance...
Old 09-17-2004, 07:00 PM
TT_Vert's Avatar
about 4 months ago. its been perfect though
dave
Old 09-17-2004, 07:43 PM
C5kid's Avatar
what kinda a flywheel/clutch and who did it? thye have to balance the fly/ pressure plate at teh same time on a C5, maybe a weight broke off or fell out of the flywheel this would cause the vibration.
who put the stuff in for ya?
Old 09-17-2004, 07:45 PM
TT_Vert's Avatar
was a z06 one put in by the dealer. It hasnt vibrated in the 6k miles and 4 months ive been using it.
Dave
Old 09-17-2004, 09:08 PM
C5kid's Avatar
is the car under warranty yet? if so take it back..... i seen yuor post over on the corvetteforum i am not sure what to say, it really does sound like a drivetrain issue if it is only doing it @ certain rpms
Old 09-17-2004, 10:05 PM
TT_Vert's Avatar
it is under warranty but the car is modded and i really dont want any prroblems. I want to try to isolate the problem first. I wonder if a bent valve could cause this vibration. I had a tad of valve float after iput on some 1.8 rockers the other day. I put new springs on last night and checked pushrods and no more float, but i have this vib. IM not sure if it was there before but any input is appreciated
Thanks
dave
Old 09-18-2004, 01:22 AM
Louis's Avatar
What kind of clutch? I had a spec come apart on a customer once, and it caused this same vibration. It was fine for the first 2k miles, but slowly began to vibrate.
There are only a few things that could cause a vibration:
Prop shaft
clutch
balancer
With the clutch in, it makes no differece, that leaves you with 2 options Clutch pressure plate/flywheel( not the disk, it is not turning when the car is in gear clutch in) or the balancer.
Old 09-18-2004, 03:35 AM
TT_Vert's Avatar
could also be engine related.
D
Old 09-18-2004, 08:35 AM
C5kid's Avatar
if you wann check your valves quick get a straight edge peice of metal take off the rockers and lay it across the top of the valve stems, i doubt the vlaves are bent from a little float,
i have ls6 springs on my heads w/ a big cam and was getting valve float and never bent any of mine.....
Old 09-18-2004, 12:36 PM
SSactionLs1's Avatar
If it was a rotating peice wouldnt it vibrate at ALL rpm's?
Old 09-18-2004, 04:21 PM
TT_Vert's Avatar
i dunno i was thinking perhaps as the part moved faster it balanced or something. kinda like a tire out of round will vibrate until a certain mph and go away.
Dave
Old 09-18-2004, 06:20 PM
TT_Vert's Avatar
the vib went away, perhaps it was because i had my MAF unplugged doing VE tuning?? lol who knows
thjanks
dave
Old 09-18-2004, 11:20 PM
JBsC5's Avatar
check the plug wires..
Quick Reply: 2000 C5 vibration only between 800-1600 rpms
