anyone familiar with the fm9 cam?
Old 09-20-2004, 11:12 AM
Turo's Avatar
Default anyone familiar with the fm9 cam?
specs of it are 232/236 .585/.598
yes i tried the search, but did not find much
how is the idle? is the clearance ok with stock heads? my main worry is that the car is a daily driver and for now, i only have 3.42 gears on an m6, and im assumming the cam will like 4.10 gears much better, should I be ok with 3.42 for the time being (while i save up enough $$$ for a new rearend), or will the surging be a little too much?
Old 09-20-2004, 02:04 PM
cyphur's Avatar
i'm gonna be running tsp's 231/237 595/598 112 on stock 3.42's for a while, i'm in the same boat as you(savin up for a rear-end). she shouldn't be too unmanagable, just gotta keep her a little higher in the rpm range. clearence should be fine with stock heads. idle will be pretty nice on a 112 if you get her tuned in well.
Old 09-20-2004, 04:29 PM
Turo's Avatar
the fm9 is actually on a 114 lsa, so im hoping the idle shouldn't be too bad with good tuning.
Old 09-20-2004, 05:07 PM
jrp
SN95 Director
jrp's Avatar
Vince had one, said he hauled *** with it.
Old 09-20-2004, 05:46 PM
Grant B's Avatar
How are the ramps on the FM cams? Good or bad for spring life? I need a no-maintence open track cam.
Old 09-20-2004, 07:30 PM
calongo_SS's Avatar
FM using cam motion lobes, which are very aggresive, more so than the comp xe-r lobes. Valve spring life will be a concern. Probably need to check them every 15k to 20k miles.
Old 09-22-2004, 01:42 PM
Turo's Avatar
yep, the cam is probably hell on valvesprings. im already planning on checking them every 10k miles, maybe replace them every 15k-20k depending on how they look.
Old 09-23-2004, 12:32 AM
01_SuperSlow's Avatar
fms cam motion lobes are softer (less agressive) than comp cams xe-r lobes
Old 09-23-2004, 01:06 AM
pdd
pdd's Avatar
i thought so too
Old 09-23-2004, 10:21 AM
cyphur's Avatar
Originally Posted by pdd
i thought so too
Old 09-24-2004, 07:35 PM
Turo's Avatar
im sorry, you guys were correct, they are less aggressive than the xe-r
well, i am between this cam, and the FM13. both look good!
Old 05-17-2005, 09:49 AM
HartAttack's Avatar
Bringing this one back up.
Anyone use this cam?
I am planning on using it for my D1sc setup....any feed back ? Results?
Old 05-17-2005, 11:24 AM
Turo's Avatar
Shoot VINCE a pm, I know he ran it for a while.
