Whats The Highest Youve Spun Your TREX To??
Old 09-20-2004, 05:18 PM
2MuchRiceMakesMeSick's Avatar
Default Whats The Highest Youve Spun Your TREX To??
Who in here has spun their trex the highest. I have taken mine up to 6400 but im still on a stock bottom end. Is there anyone that goes higher then this?
Old 09-20-2004, 05:22 PM
jrp
SN95 Director
jrp's Avatar
what was the point of installing the T-Rex if your not even shifting at the optimum range . i believe jason shifted his @ 7k for the best et. Smokin01TA is up there im sure as well, 6900 or so IIRC.
Old 09-20-2004, 05:24 PM
Well its my daily driver, I plan on a forged 408 soon. Im just wondering when the trex quits pulling. I remember a graph going up to 7200 with a trex but I cant seem to find it.
Old 09-20-2004, 06:04 PM
Fireball's Avatar
I have my shift light set at 7000 rpm
Old 09-20-2004, 07:12 PM
Lostpatrolman's Avatar
I dont even think the trex peaks until until 6500. After that it looks like the graph is flat until atleast 7k rpm.
Old 09-21-2004, 10:03 AM
93LS1RX7's Avatar
Hell I have a stock short block and shift mine on the street at 7k.
Old 09-21-2004, 10:19 AM
You have stock internals, spray it reving to 7k, gooood lord man
Old 09-21-2004, 10:22 AM
chrdij's Avatar
408+Trex= one bad motha! I can spin this cam all the way to 7100 rpm with no problems on my a4. It just keeps pulling on the top end. i was very pleased, since I went from a stock ls1 on the juice, to a 408 iron block (with trex cam) with nitrous. Good luck with the setup and keep us up dated!
Old 09-21-2004, 10:59 AM
DanZ28's Avatar
Mine will hit the 7400 RPM limiter pretty fast! I shift around 7100 normally, but I swear it still feels like it's pulling hard past that. Your only just starting to use the potential of this cam when it reaches 5500 RPM and above...
Dan
Old 09-21-2004, 11:02 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
I was turning my stock 346 LS1 with the T-Rex to 7200 rpms going across the finish line.
I made 120 passes doing this. She is sitting in my garage just waiting to go back in the Hot Rod. Most likely she will get a freshen up 1st.
Coach
Old 09-21-2004, 11:04 AM
Juiced's Avatar
i've seen 1 guy at the track rev it to 8000k on a forged 382 all bore. i sat in the car during his last 1/8 mile run and couldn't believe my eyes as he burried the stock tach then the shift light came on a few milliseconds later
Old 09-21-2004, 02:52 PM
93LS1RX7's Avatar
Stock pistons etc. I have upgraded rods, springs, timing chain and oil pump but the rest is stock.
I dont spray it at 7k are you crazy, the juice cuts at 6800 haha, if it blows just a better reason to upgrade and go with a forged stroker!!
Old 09-22-2004, 12:52 AM
Hhaha well if it cuts out at 6800 thats ok As for the stroker, I heard that, Ill use it for an excuse to buy a 408
Old 09-24-2004, 10:59 PM
99HUGGSS's Avatar
mine makes power all the way to the rev limiter which is set at 7200
Old 09-25-2004, 03:02 AM
35th SS's Avatar
taken mine up to 6800 on 3rd and still pulling crossing the line.need to raise rev limiter to 7200 on 1st and 2nd.hitting it on 6600.stock bottom end.sorry no shift tables to show you when you pm me earlier.
Old 09-25-2004, 09:15 AM
King of Pigskin Knowledge
BuckeyeROC's Avatar
7200 rpm here too.
Old 09-25-2004, 09:43 AM
hydfixer's Avatar
I am puting the motor in the car now with T-REX in a 427 alum, block stroker, whay do you think I should set the shift light at? and what do you think that cam will be like in the stroker/
Old 09-25-2004, 11:55 AM
SpdfreakLS1's Avatar
Why the hell am I only peaking at 6500 with the rex?! I took it to 7200, the power has already died. i made 424sae wheels through a 12 bolt. but the peak wasnt high like i always hear about and see.
Old 09-25-2004, 05:45 PM
The Juggernaut's Avatar
Shift is 500 past peak power.
I don't have a Trex but have around 400 passes @7k on a stock bottom end.
No problems yet.
Old 09-26-2004, 01:21 AM
DAAAMMMM........what do I think it would be like....REDICULOUS ill find out after I get all my body/drive triain/suspension built up for it.
