Mti X1 what tc if any?
Old 09-20-2004, 08:18 PM
ca99ta's Avatar
Default Mti X1 what tc if any?
If I buy this cam do i need a torque converter or do I even need one/ its for a daily driver with an a4 3.23?
Old 09-20-2004, 09:10 PM
WILWAXU's Avatar
It's a great cam. But, I suggest getting a converter first.
Old 09-20-2004, 09:43 PM
Ragtop 99's Avatar
Old 09-21-2004, 10:36 AM
PREDATOR-Z's Avatar
Yeap, stall first with cam in mind. 3500 minimum>>>>>4000 if more track than street. 2.5/2.7 str
Old 09-21-2004, 04:24 PM
beardWS6's Avatar
Get a 3600 for this cam if for street. Alittle higher if for track. I`m going to restall mine when I can to 3600rpms. This cam likes it up alittle higher than 3200. Check Sig! If you give me your E-mail address I will send you my dyno sheet, N/A and on Spray!
Old 09-21-2004, 06:55 PM
ca99ta's Avatar
Default stall
TCI Stalls
StreetFighter® 280° to 300°
gears 3.55 to 4.56
rough idle, large fuel system, raised comp. ratio 3000 to 3400
*Super StreetFighter™ 280° to 310°
gears 3.73 to 4.88
rough idle, large fuel system, raised comp. ratio top end power 3500 to 3800
I havent got many mods yet but would either one of these work or do I need to up grade my fuel system and my gears I only got stock 3.23's or would I be fine with what I got for now thanks for any info???
Old 09-22-2004, 01:27 AM
PREDATOR-Z's Avatar
TCI 3500 will work great and is 2.5 str, I used to run it with 3:23's and was well behaved for the street and track. Eventually went with 3:73's to inprove my 60's. Now it is wicked.
Old 09-22-2004, 02:46 PM
kickassT/A's Avatar
i like my vig 3600. if going with a yank, i'd get an ss4000.vig's stall higher than they are rated, which is why i went 3600.
