HELP - Cam install: rear retainer plate????
Old 09-22-2004, 06:16 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Default HELP - Cam install: rear retainer plate????
Is there a there a rear retainer plate that prevents the cam from sliding too far back into the block? Or does the combo of the cam gear and timing chain keep the cam in place? TIA
Old 09-22-2004, 06:20 PM
2001CamaroGuy's Avatar
The rear cover (that holds the rear main seal and covers the oiling passages in the block) covers the rear of the cam. The cam will slide "back" some in the block but not very much (just enough to make getting the gear on the pin a PITA).....
Old 09-22-2004, 06:45 PM
ls1290's Avatar
Cool! Thanks for the info I was pretty sure there was not one when I was disassembling the motor.
Old 09-22-2004, 06:54 PM
thinking you lost something?
Old 09-22-2004, 07:39 PM
ls1290's Avatar
Yes
Old 09-22-2004, 08:37 PM
DEEZ98Z's Avatar
I thought something was wrong with my cam too the first time There was allot more play then I thought there should be, but I was wrong.
