402 shortblock pics
402 shortblock pics
Finally got the shortblock assembled and is ready to be drpped in this weekend. I would like to say thanks to all the people that have helped with my questions so far
Here are some specs on it:
GM LQ4 4.00" Bore Blueprinted Iron Block
Scat LS1 4.00" Forged Billet Crankshaft
Callies LS1 6.125" Forged Billet Connecting Rods
Diamond -15cc Dish Forged Thermal Coated Pistons
Diamond Pro-Select Piston Rings
Diamond Chrome-Moly Harden Wrist Pins
Diamond Spirial Wrist Pin Locks
Chevite Main Bearings
Federal Mogal Rod Bearings
Federal Mogal Cam Bearings
ARP 6pt Main Studs
ARP 12pt Head Studs
ARP 12pt Flywheel Bolts
ARP 12pt Harmonic Balancer Bolt
ARP 12pt Header Studs
ARP 12pt Connecting Rod Bolts
Blueprinted and Custom Ported LS6 Oil Pump
Rollmaster Double Timing Chain
New gaskets and seals
ARP 6pt Main Studs
ARP 12pt Head Studs
Originally Posted by 2001CamaroGuy
Is the fitting on the lifter valley cover for PCV (or similar)? How are you going to get that line out under the manifold (or are you using a different manifold)?
Originally Posted by ls1290
I am hoping to make 750ish rwhp with the F-1R Procharger I am also installing.
As if the 402 wasnt bad *** enough....your putting a super charger on it.
