LG 222/228 113 LSA vs Comp 231/237
Old 09-27-2004, 03:28 PM
black_z's Avatar
Default LG 222/228 113 LSA vs Comp 231/237
Specs: 222/228 .567"/.583" 113LSA Is anyone using this cam? A local has this cam for sale, but another friend has a comp 231/237 112 .589/.595 on an XER that I may possibly buy. Which do you think would work better with stock heads? Drivability isnt a huge deal to me, I dont drive in stop and go hardly at all, mostly highway. Im looking for the cam that will perform the best street racing, and at the track. The car is a 6-speed. Thanks.
Old 09-27-2004, 03:38 PM
Hysteria's Avatar
The XE-R. It will pay off later when you get some ported heads.
Old 09-27-2004, 03:47 PM
luv2spd's Avatar
Yes, the XE-R will give you better gains under the curve as well due to the fast ramps.
Old 09-27-2004, 04:12 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Make sure it's a COMP XE-R cam. The TSP 231/237 (.598/.595) is a Lunati grind I believe and is not on XE-R lobes.
Old 09-27-2004, 04:31 PM
black_z's Avatar
Its a speed inc custom grind. I called speed inc and they said it was on an XE-R lobe.
Old 09-28-2004, 02:21 PM
black_z's Avatar
TTT looking for more opinions. Thanks
Old 09-28-2004, 04:20 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The 231/237 .598/.595 112+2 Camshaft is our TSP 231/237 cam. It is produced by Lunati for us & is a specific grind only for TSP.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-28-2004, 04:24 PM
black_z's Avatar
I was aware of that, but this cam was custom ground by speed inc for my friend, and now hes moving to your magic stick V3.
Old 09-28-2004, 06:12 PM
c5jonny's Avatar
FWIW I picked up 48 rwhp & 30 rwtq with the tsp 231/237 cam package, with stock heads. This is on an a4 c5, an underdrive pulley was also installed though.
Quick Reply: LG 222/228 113 LSA vs Comp 231/237
