A Peak Inside The Engine Of The APE Shop Car
Here is a sneak preview inside the powerplant of the APE Shop Car, now dubbed Project Black Mamba.
Our goal is to have it fired up and testing within the next two weeks, our second goal is to run 7's at the Thunder Shootout in November, and after who knows.
It will be a 359ci Iron Block with our big daddy Procharger F-2 strapped to it. With any luck we should be able to make north of 1200hp at the flywheel with this set-up. Stay tuned for details.
Pics can be seen here.
Originally Posted by 427
Nick,
Ran a 320ci gen 1 last night with f2. Made 1300+ at 31 psi.
That thing will rock if the head gaskets are happy!
Kurt
Kurt
We shall see here pretty soon assembly should be done this weekend.
Under criminal investigation for fraud
Originally Posted by under_construction
How light is that Callies crank?
The Callies crank weighs in at 38lbs!!! Special thanks to Brook, Nick and all of the guy's over at Callies for hooking us up with this killer Crank! BTW, this is there LS1 racemaster XLS. If anyone wants one you can buy them through us.
Chris, the rods don't stretch as much as they used too. GRP has come a long way in aluminum rod technology. We now get a lot of runs out of these rods. Also a special thanks goes out to Troy over at GRP for getting us these killer rods.
Originally Posted by Flyer
Is that the crank that comes in your forged shortblocks, mainly the 408?
No sir! We use just a standard racemaster in our 408's. You could upgrade to that crank though.
No AFR heads, just some badass 4.8/5.3 liters from ET Performance. Big thanks to Cary, Craig, Mike and the rest of the guy's at ET that busted their *** to get me these heads. They are simply the best 5.3 liter heads that could have been made!!
