347 rotating assembly question
im thinking about purchasing a lunati rotating assembly for my motor. im planning to get the one for stock cubes (not the 383 stroker kit). my question is, will i have to send my block to a machine shop, or can i just install the kit in the block, as is?
my $0.02... Would be a good idea to send it to a machine shop. You can install it straight out of the box, but if the crank is not balanced, or anything is off, it will cost you alot more than sending it to the machine shop in the first place.
