Tune UP
Old 09-30-2004, 07:12 PM
supa ss's Avatar
Default Tune UP
Does any one know how to get out the number 8 plug...HELP
Old 09-30-2004, 09:15 PM
Viper's Avatar
I put a pillow on the battery and climb up on it, both knees on the battery facing the windshield. You can get your arm in there. Otherwise I've also done it from underneath the car, again it can be done with just the wrench and socket.
Old 09-30-2004, 09:28 PM
2001CamaroGuy's Avatar
I always found it easiest to jack the car up, get under the car, and reach up from under the car. There just isn't enough room (I think) with the coil packs on there to get at #8 without getting all cut up. Now if you remove the coil packs then you can get to #8 from the top without any problem but to me it's much faster to jack the car up than remove the coil packs.
Old 09-30-2004, 09:42 PM
luv2spd's Avatar
Yep. I always get mine from underneath.
Old 10-01-2004, 06:26 AM
Viper's Avatar
Yes, from the top I assumed he knew to take off the coil packs. Mine are only held on with 3 bolts so it's pretty quick to remove.
Old 10-01-2004, 07:35 AM
Johnny Ray's Avatar
I also remove the coil pack.
Makes it a breeze!
Old 10-01-2004, 07:39 AM
supa ss's Avatar
THANKS alot guys...you all have been a great help...
