Will a T-REX clear in a 6.0???
Old 10-05-2004, 02:20 PM
1BADFNHuggerZ's Avatar
Default Will a T-REX clear in a 6.0???
I am asking this b/c I have one brand new complete 6.0 that I want to throw in my Z28. I was also wondering if I flycut the pistons and mill the heads 50 thousands could this possibly work??? I am asking this because the compression of the 6.0 is low. This is also using the stock valves of course with a very good valve job.
Old 10-05-2004, 02:22 PM
Boostaholic's Avatar
Yes, the base circle is the same, it will slide right in.
You need to check your PTV clearance to make sure you have plenty, I don't even think you have to mill the heads down, my car has TREX on a 6.0 408 stroker with stockish heads, I have pretty big valve releifs in my pistons, and HPE did the PTV clearancing on my setup for me.
Make sure you get good springs
Old 10-05-2004, 02:41 PM
P/V clearance is what I'm trying to verify, but I am running stock pistons and want more compression for better performance. I just wondered if it'd clear on stock heights w/o flycutting, and if I wanted to mill the heads would it be sufficient if I flycutt the pistons?? I want compression to be around 11:1.
Old 10-05-2004, 03:11 PM
Maybe Jason from Thunder will chime in and give me some advice???????????
Old 10-05-2004, 04:06 PM
chpmnsws6's Avatar
sell your heads and buy 5.3 heads
Old 10-05-2004, 04:27 PM
I can shift faster than you.
Jason99T/A's Avatar
The cam will work just fine with stock, unmilled 6.0l heads. You will need to flycut if you plan on getting the heads milled, or at a VERY minimum check PtV after the milling/valvejob see where you stand. The valvejob may sink the valve further into the head (depending on the shop that performs this), thus giving you more clearance.
Jason
Old 10-05-2004, 05:22 PM
Jason
Thanks Jason "The T-REX Doctor". I hope it works well!!!!
Old 10-05-2004, 05:24 PM
I have a set of 5.3 stock heads, a set of Ligenfelter Stage II LS1 heads, and the 6.0 stock heads on the engine.
Old 10-06-2004, 09:29 PM
Can someone tell me what the compression is on a stock 03 6.0, and also the h.p. rating???
Old 10-07-2004, 09:47 AM
Taspeed's Avatar
man...the 6.0's have a .045 dish in the top of them if you have the low compression lq4, I've got to check pv clearance on mine before the cup cam goes in but I don't anticipate having to fly cut them any.
Old 10-07-2004, 05:11 PM
I have the LQ9. All should pan out. Hopefully she'll scream.
Quick Reply: Will a T-REX clear in a 6.0???
