which one ....224/581=112 or 231/237
Old 10-12-2004, 12:20 AM
2KSSLS1's Avatar
Default which one ....224/581=112 or 231/237
which of these are better tq and 1/4 times ..
it's too hard too pick a cam lol
Old 10-12-2004, 01:09 AM
Tech's Avatar
Old 10-12-2004, 01:29 AM
Z-286speed's Avatar
I would go with the TSP, they put down around 400 wrhp with stock heads. Then its up to you to drive the beast.
Old 10-12-2004, 01:33 AM
jrp
SN95 Director
jrp's Avatar
tq i'd have to say the 224, better top end the 231. better 1/4, the 231 if your setup for it; i.e gears/stall, tires, ect.
Old 10-12-2004, 03:33 AM
GTS346's Avatar
Is that 224 a Comp XE-R?
Old 10-12-2004, 05:20 AM
CCSRACER's Avatar
Yes, that Comp grind is xer.
Old 10-12-2004, 06:52 AM
racrx's Avatar
224 more tq
Old 10-12-2004, 07:01 AM
STF Veteran
99-LS1-SS's Avatar
Like JRP said. The 224 cam will give you decent power in the low medium and higher rpms and the 231 will give you decent power in the medium and good power in the higher rpms. If you have gears or you are going to get gears go with the 231 if not the go with the 224. Good luck.
Old 10-12-2004, 08:56 AM
Ryan02SS's Avatar
99-LS1-SS summed it all up for you. Stock 3.42 gears 224 cam 3.73's or 4.10s then the 231/237. My bet would be two identical cars, same drivers, one with the 224 and the other had the 231/237, the kicker being they both had stock 3.42 gears. My bet would be the 224 car would be all over the 231/237 car due to the lack of lowend and midrange with the lazy 231/237 lobes. The TSP cam needs to be geared to be effective. MHO
Old 10-12-2004, 09:10 AM
CRASH Bandicoot's Avatar
My buddy has the 231 and its a nice cam, you have to get a really good tune because the car is a chore to drive.
Old 10-12-2004, 09:38 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
The 231/237 with 4.11 gears, as mentioned above.
Car is not a chore to drive with good tune.
Old 10-12-2004, 10:39 AM
PREDATOR-Z's Avatar
If you want a higher power band just get the 224 on a 0 advance in the grind and you'll still benefit from the trq under the curve.
Old 10-12-2004, 11:00 AM
LS1TECH Sponsor
Steve Burger's Avatar
231 is not a chore to drive. I love mine but do have 4.10 gears. I also have a good tune.
Old 10-12-2004, 11:30 AM
Tranzor's Avatar
I also have a TSP 231/237 cam and it isn't a chore to drive because of the two factors mentioned above:
4.11 gears in my Moser, and a good tune.
Old 10-12-2004, 09:55 PM
2KSSLS1's Avatar
how 's the 231 on street and the 224
Old 10-12-2004, 10:04 PM
STF Veteran
99-LS1-SS's Avatar
I have the 224 and it is a great all around cam. Not too radical not too mild. Gives you decent power. If it is your first cam I would probably lean towards the 224 cam.. I don't think you will be disappointed. Good luck.
Old 10-12-2004, 10:28 PM
2KSSLS1's Avatar
what's ur 1/4 on the 224 or 231 ??
Old 10-13-2004, 07:57 AM
!LS1 11 Second Club
You'll see 224 cams trap around 114-116. While 231/237's trap around 116-118 on usual M6 setups (A4's trap a bit less). Generally mid 12's for 224's, low 12's for 231/237's on stock heads.
It's hard to generalize, 'cause anyone with a good suspension, rear end and tire can get either of these cams in the 11's easily.
Old 10-13-2004, 08:17 AM
STF Veteran
99-LS1-SS's Avatar
What he says is pretty accurate. My car runs mid to low 12's and I trap anywhere from 110 to 112 mph. My car is an automatic with a very conservative torque converter.
Old 10-13-2004, 09:27 AM
LS1TECH Sponsor
My times with the 231 are in my sig. I do have heads and a lot of suspension work. My car is getting faster as I figure out the suspension. I expect to drop another .2+ this year just from suspension tuning.
Like said above there are a lot of variables on the 1/4 time with either cam. You never mentioned what you have done to the suspension or what tires you will be running.
Quick Reply: which one ....224/581=112 or 231/237
