Lightest LS1/LS6 Valves?
What are the lightest LSx valves available on the market (Besides titanium).
Goal is to have a light valvetrain
Tit retainers
Tit seats
918 springs
Valve ??????
My goal is to achieve at or lighter than 120 gr / valve assembly
Tit retainers
Tit seats
918 springs
Valve ??????
Brian Tooley at TEA posted wts for valvetrain related compnents a while back,maybe do a search or look up all post started by Brian.P.S. it was about 3 or 4 monthes ago.Good luck!!
Originally Posted by PREDATOR-Z
Hmm, according to this with LS6 valves, 918's, Tit ret, super 7 ... the best i can come up with is 158.7g of moving parts /intake assembly.
So in your opinion, what is the moving mass of the LS6/918/tit ret/S7 locks ?
If you guess at 1/2 weight of spring so 158.7 - 35.1 = ~ 122.6
would i be right in assuming so?/
If using LS6 valves, is there any limitation as far as ported heads, or the size of the cam ? I understand that I'd have to use custom pushrods to make the geometry right...but is there anything else I should look for ?
if LS6 valves and stock LS1 cam then 7.35
Other than that I think the valve job LS1/LS6 is the same, or at least interchangeable.(valve seats)
