MS3 cam go wrong?
MS3 cam go wrong?
ok i have been looking into this new magic stick cam, freaking awsome!
1..but if i were to throw that cam and springs,push rods, would i have any problems with the stock oil pump?
2.. and would that cam be to much for my stock chain?
3.. I also see that MTI has around the same lift as MS3 but on MTIs web it recommends a way bigger cubd engine. so is this MS3 ok for me?
4.. and also with this new setup and tune will i pass smog? thanks skeeter
2. Again I have stock timing chain with no problems.
3. I love this cam, I put down 416rwhp with 3.42 gears now with 4.10 it may be a little lower will see.
4. If your emissions is just plug into the OBD port then you will pass but it has to be tuned.
LS1Tech Premium Sponsor
It works really well if you have some converter to back it up
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
