*wats that noise?!?! :(
Old 10-20-2004, 10:45 PM
StyLishSS's Avatar
Default *wats that noise?!?! :(
okay, heres my problem. lets say im cruising at like 40 50 60 mph. if i give the car alittle gas to pick up, it sounds like somthing is rattling in the engine, almost like little metal ***** hitting eachother. i have no idea this isnt my area any help would be appriciated.
Old 10-20-2004, 10:50 PM
longdaddy's Avatar
this is most likely detonation, commonly referred to as "pinging". What are your mods/mileage? What kind of gas are you running? Did you notice if it only happens when it is hot out?
Old 10-20-2004, 10:53 PM
2MuchRiceMakesMeSick's Avatar
what kind of gas do you have? hopefully not 87, try some 93 out and see if that helps. Have you done any mods recenly?
Old 10-20-2004, 10:55 PM
cyphur's Avatar
good god, do people actually put 87 in LS1's? I think that should be grounds for a public beating.
Old 10-20-2004, 11:04 PM
StyLishSS's Avatar
i only run premium, and the engine was just rebuilt at 65k 3or4 thousand miles ago.. i hydrolocked it , its still under warranty. My mods are all basic nothing but some bolt-ons. Im going to get it checked at the shop within the week, i would just like to know if its serious.. when i rev my car in neutral or park it doesnt happen, only when im in gear, accelerating. its kind of like a crakling noise sounds like... hard to explain thanks for the quick replies tho
Old 10-20-2004, 11:33 PM
longdaddy's Avatar
You may be running too lean. Fuel filter, O2 sensors, MAF, etc. I had a same problem - with the same symptoms you describe. Turned out to be a bad cat converter (56k miles) - but it took almost half a year since I started hearing detonation until cat started smelling bad and threw "inefficiency" code. Check your A/F ratio, Fuel pressure, and see if your O2 readings are consistent between banks 1 and 2.
Forget going to the dealership, they will not aknowlege that you have a problem unless the car is throwing codes
Old 10-21-2004, 01:19 AM
I know, there is a girl at work and her z was doing the same noise he is describing. I told her to only put a MINIMUM of 91 in there.
Old 10-21-2004, 01:31 AM
goober35's Avatar
91 where do you get that. All i ever see is 93.
Old 10-21-2004, 04:06 AM
Try 7-11.
This could also be a loose spark plug wire. Check to make sure they are all tight.
Old 10-21-2004, 04:34 AM
CurbcheckSS's Avatar
Think I have the same problem, you only hear it under part throttle correct? Kinda sounds like someone garggling metal? or muffled chatter? Mine does the same thing.
