Trex or MS3
Old 10-20-2004, 11:00 PM
ArticLS1z's Avatar
Default Trex or MS3
what do u guys think would be the best for my setup...i know ill be doing dual springs also with either cam obviously. and a dyno tune from Ed.. it is a daily driver... doesnt see alot of milage around 10k a yr or so... but i want an all out set up .. my mods are listed in my sig as for the rest of the exhuast it is a bullet and dump off each header.. and the trans was just rebuilt with all the goodies..
the times in my sig were pre LT's and new trans...
TIA , Will
Old 10-20-2004, 11:20 PM
jrp
SN95 Director
jrp's Avatar
t-rex
Old 10-20-2004, 11:32 PM
LSUxBlake's Avatar
I vote for the T-rex.
2MuchRiceMakesMeSick's Avatar
TRex. I drive mine daily.
Old 10-20-2004, 11:40 PM
ArticLS1z's Avatar
How's ur idle and what the idle speed ? and what are u turning Rpm on the topend ?
Old 10-20-2004, 11:53 PM
luv2spd's Avatar
I would go for the ms3. It might not give quite as much peak power, but I think it makes it's power in a much more useable range. It would also have better driveability.
Old 10-20-2004, 11:57 PM
ws.6kid's Avatar
I vote MS3
Old 10-21-2004, 12:50 AM
BlueSix's Avatar
I vote for the LG juggernaut cam
Old 10-21-2004, 01:41 AM
I set my idle at 850, but you it will run at 650 but does not sound near as good in my opinion. As far as top end goes, the trex will pull to 7200. I have not seen any people go past that.
Old 10-21-2004, 02:15 AM
35th SS's Avatar
trex plus you have the t/c already.
Old 10-21-2004, 02:35 AM
I can shift faster than you.
Jason99T/A's Avatar
I only have experience with the TReX. I ran it with stock heads a few months back. With tuning and gears, it made for a pretty quick ride. I can't stress the tuning and gears enough!
With your A4 setup, the converter should work well. Look into a 3.73 or steeper gear and the car should fly!
Jason
Old 10-21-2004, 04:39 PM
ArticLS1z's Avatar
Any other opinions ?
Old 10-21-2004, 04:59 PM
beardWS6's Avatar
What power are you getting with the TREX?
Old 10-21-2004, 10:15 PM
IntenseSS's Avatar
Me too!!!!!!
Old 10-21-2004, 10:29 PM
dug
dug's Avatar
I like the specs of the MS3 cam. Probably work ok on a daily driver.
Old 10-21-2004, 11:24 PM
ArticLS1z's Avatar
Originally Posted by IntenseSS
Me too!!!!!!
Specs ? i couldnt find it on LG's site ?
Old 10-22-2004, 12:31 AM
mnc2886's Avatar
You got a big mother of a stall. You put a t-rex in there, you are going to take off like a bat out of hell.
Old 10-22-2004, 12:56 AM
BlueSix's Avatar
It's BIG, and you aren't gonna find out the specs. After the G5X2 debacle LG won't release the specs on their cams. You can PM Louis, he can get you some info about it. There is some info about it on page 4 of this thread https://ls1tech.com/forums/drag-racing-results/222889-new-cam-only-record-10-64-126-a.html
Old 10-22-2004, 01:00 AM
BlueSix's Avatar
it also sounds wicked.
http://www.ls1speed.com/movies/jugga_hi.WMV
Old 10-22-2004, 01:07 AM
mnc2886's Avatar
Too quiet...
